Question about Nextbook Tablets & eReaders
Nextbook thermal shutdown - Nextbook Tablets & eReaders
My nextbook will not hold a charge.
Hello, Jessy -
The rechargeable battery for your Nextbook probably needs to be replaced. Eventually all rechargeable batteries need to be replaced.
Make sure you order or purchase in a bricks and mortar store the right battery for your Nextbook.
I don't know what model of Nextbook you own, but these instructions may prove helpful to you:
https://www.ifixit.com/Guide/Nextbook+8+Battery+Replacement/39351
If you do not feel comfortable in following the steps provided in the link above, find a reputable computer repair business near you, take your Nextbook there, and ask a technician there to open the Nextbook, determine what battery is needed for replacement, order the battery, and install it. Note: You will probably be provided an estimate of the cost of the work and will probably need to pay an initial fee which will be deducted from the final cost of the battery and the technician's work.
Best wishes.
Apr 23, 2018 | Nextbook Tablets & eReaders
How do I find out which product I have? It is a Nextbook with Windows 8.1
Nextbook 8 Tablet - Welcome to Nextbookusa.com
nextbookusa.com/productdetail.php?product_id=22
The Nextbook 8 comes with the Windows 8.1 operating system, 16GB of internal memory that can ... With WiFi and Bluetooth support built-in, the Nextbook 8 can connect with everything you need at home and on-the-go. ... Product Registration.
Nextbook 10.1 - Welcome to Nextbookusa.com
www.nextbookusa.com/productdetail.php?product_id=21
The Nextbook 10.1 comes with Windows 8.1, an Intel® ATOM™ quad-core ... Playing video games is better, too, with the 3-axis G-sensor support, which lets you immerse yourself and move the way you need to. On-the- ... Product Registration.
Nextbook Flexx 10.1" 2-in-1 Tablet 2/32GB Quad Core ...
Dec 26, 2015 | Nextbook Tablets & eReaders
My tablet keeps shutting down. Says thermal shut down. How can I fix this problem? It isn't even 3months old and won't stay on for more than 2 or 3 minutes.
Nextbooks do this when playing intensive games. They just aren't up to the demand on the CPU. Unless you were clearly warned about ths issue I'd say it is a warranty claim. Try to swap it for a games -capable brand.
Nov 19, 2015 | Nextbook Tablets & eReaders
My tablet keeps shutting off
Nextbook 8 NX785QC8G shutting down on its own FreakTab com
shaunmt might have answer
Read through the other threads here about the NX785QC8G. They all have problems with the battery connector. The cable comes loose from the socket, which leads to incorrect batter level monitoring, sudden shutdowns and improper or no battery charging.
You'll most likely have to remove the back of the tablet, unplug and firmly replug the batter cable and consider options to prevent the cable from pulling loose again.
Jun 23, 2015 | Nextbook Tablets & eReaders
How to unlock apps on nextbook
1. Back up everything you feel is important before you start.
2. Charge your device to 75% or more before you begin to prevent unwanted shutdowns.
3. This method will only work for the versions of Nextbook 8 bought before August 2013. Check the back of the tablet and if the serial number begins with YFG1013, YFG1113 or higher, this procedure is not for you!
II. Necessary Downloads
1. SMT_Next8HD8G_Mod_Recovery.zip [Download link available in this post]
2. Kyser_Root-signed.zip [Download link available in this post]
III. Rooting the Nextbook 8
1. Extract SMT_Next8HD8G_Mod_Recovery.zip to a folder on your desktop. You should end up with a file calleduImage_recovery with no extension.
2. Connect your device to your PC and copy both uImage_recovery and Kyser_Root-signed.zip to your device's external SD card (not the internal memory, insert a microSD card if you don't already have one); do not put them into any subfolders just drop them in the main folder of your device's external SD card.
3. Power down your device and reboot to the modified recovery you have just copied. To do this, with the device powered off, press and hold the Volume Up + Volume Down buttons with the Power button until you pass the splash screen, a black screen and you see the recovery menu.
4. Use the Volume Up and Down buttons to highlight the 'Flash zip from EXT card' option and the power button to confirm the selection.
5. Once flashed, go back to the main menu and select 'reboot system.'
Once the Nextbook 8 reboots, check for the SuperSU app in the app drawer (install it from the Play Store if you don't find it) to verify you are rooted!
Sep 29, 2014 | Tablets & eReaders
Nextbook 8 Power Button won't work
dont charge it and let it shutdown den open it up
May 22, 2014 | Tablets & eReaders
Nextbook tablet resets upon full shutdown
The problem could be that you are pressing down the power button and the volume button at the same time when you shut down. That will cause an android tablet to reset itself. There may be an issue with the power shut off button.
Mar 05, 2014 | Nextbook Premium 8 Se Android
Tablets & eReaders Logo
85 people viewed this question
Top Nextbook Tablets & eReaders Experts
D. E. Hev
Tom
Dustin
Dustin
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
