Question about Sewing Machines
I need the manual for a Nelco F600. Do you have it or know where I can get one. I was given a machine but think it has been in storage for a long time! Need to oil and check it out.
  • Sewing Machines Master
  • 11,729 Answers
A manual for a similar model would be a benefit. Most machines operate and thread the same. Yes, you should definitely clean and lube your machine before trying any sewing. Tri-Flow Synthetic Lube from the hardware store is a good product to use because it does not dry out and turn to glue over time.
Nelco sewing machine manual free
Wheel on right side that controls the needle up and down is very tight...
Nelco Sewing Machine
FWIW, I inherited a Nelco J28 and it is the toughest machine in my arsenal. I repair horse equipment with it. The stitch quality is not the best, but it certainly sews most anything thrown at it. The only issue I have with it (and it is my issue, not the machine's) is that it has a side-loading bobbin which means the home position of the needle is also on the left instead of the middle. Having always used a centered needle makes using it seem somewhat unnatural. However, your machine appears to have the front-loading bobbin and centered needle.
Posted on May 17, 2017
  • 84 Answers
SOURCE: Janome 3022
ALL machines will require lubrication at some point.It will require covers to be removed however. Apart from the cover over the needle bar / presser foot area, I dont recommend you try taking them off as without knowledge of exactly how, you can break the retaining clips. Cleaning out the lint REGULARLY is very important - you can use a vacuum with a crevice tool.
So, remove the 'lamp' cover and needle plate, vacuum out thoroughly. Apply a drop in total to the length of the needle bar, a small amount on the presser foot shaft.Remove the black plastic shuttle, clean around it, apply a SMIDGE of oill to the 'track' on the underside of it. Thats about all you will have access to. Use proper sewing machine oil - NOTHING ELSE!
If you sew a lot, get it serviced proffessionally - they will do the areas you can't access.
Posted on Oct 22, 2007
  • 10 Answers
SOURCE: white 3-4 thread overlock speedylock model 1600 sewing machine manual needed
Manuals for all types of sewing machines can be downloaded from sewingmanualss.com.
Posted on Jul 31, 2008
  • 323 Answers
SOURCE: Where to oil a Kenmore 158-17600
Remove the top and bottom covers. Turn the wheel and put a drop of oil anyplace that moves and rubs.Also at the ends of each shaft. Open the side cover and oil the needle bar and all the parts inside that move and rub.Put a drop of oil on the hook.Do not put a good piece of fabric in the machine right after you've oiled it. Sew it off on some scraps that you can throw away.
sewman7
Posted on Apr 18, 2009
  • 1116 Answers
SOURCE: I need a users manual for a Tacsew T175 blindhemming machine.
Get with this vendor before ordering - http://www.allbrands.com/products/abp07642.html
Posted on Feb 28, 2010
  • 1788 Answers
SOURCE: I have a Nelco model
Try contacting www.tias.com, they carry a lot of old sewing machine manuals. They may be able to find one for you.
Posted on Dec 30, 2010
I'm looking for the operating manual for a Nelco 6501
hi Kathy.
this is all i could find so not sure if it will help you out but have a look.
i think if you scroll near the bottom of the page it might help you out but not sure.
Sewing Machines operating manual for Nelco 6501 Google Search
Nov 19, 2017 | Sewing Machines
Need a Nelco sewing machine mod 4102F manual.
  1. http://www.sewusa.com/index.htm try finding it on this website. maybe you will get lucky.
Jul 30, 2017 | Sewing Machines
Threading a nelco 5102
Machines generally thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading the top thread.
Nelco JA 38 Sewing Machine Threading Diagram
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Jul 29, 2017 | Sewing Machines
Need copy of Instruction manual of Nelco type A15L sewing machine
Unable to locate information regarding your particular model. You might check this web site and see if there is anything similar. Most machines from that era have the same care instructions.
Apr 15, 2017 | Sewing Machines
I have a Nelco model 217. No manual. Need to know how to thread.
This may be helpful even though not your model. Most machines of the same brand and similar models thread the same:
Be sure to RAISE the presser foot when threading the upper thread!
Oct 10, 2016 | Sewing Machines
How to thread the Nelco A2?
To find a user's manual, search the internet for:
Manufacturer + Model + the word "Manual"
Search YouTube videos for threading tutorials:
Nelco Zigzag Sewing Machine Final Test Demonstration Video
VINTAGE ALL METAL NELCO MODEL 400 2 SEWING MACHINE
NIFTYTHRIFTYGIRL Vintage Nelco model 250 sewing machine
With your Nelco, be sure that you install the needle properly. Frequently, Nelco machines take the needle with the flat side facing toward the throat of the machine--not toward the read like most other machines. The upper thread will thread through the needle's eye from the left toward the right. They also are a left needle position machine--meaning, the standard position of the needle when sewing straight stitch is at the left side of the presser foot, not center like most other machines.
Nov 15, 2015 | Sewing Machines
I need a manual for my Nelco model# N-250-B-3. I can't find one anywhere. Please help me.
I have the same machine, and just found my the manual for the Nelco, it lists both the N 250-3 and Nelco N 250-B-3.
I can scan and email it to you, can you send me your contact info? Not sure how this site works. c7e6ddb9-bb8c-4b28-845f-c3fa8fdd61d1.jpg
Jan 22, 2015 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
