Question about Hardware & Accessories
Is there a help segment at the end of the show 13 reasons why
Why You should buy Tata Hexa?
Tata Hexa is the full size SUB segment after the launch of Tata Aria. The all new Hexa is the new value-for-money and is the king in the utility segment.
Reasons to buy Tata Hexa:
• Comprehensive Safety Equipment
• Build quality
• Practicality
Apr 18, 2017 | Tata Computers & Internet
How to put a repeating decimal on a graph
You cannot. There is technique that can be used to locate a fraction on a line segment. It involves the drawing of parallel lines passing through equidistant points drawn on an intersecting line. The procedure is based on Thales' theorem.
Draw a real line (passing through 0 of course) Mark the limits of segment [0,1]
From the point 0 draw a line. Choose an arbitrary length measured by the opening of a compass. Starting from O, mark three equal segments along the second line. From the end of the 3rd segment draw a line that joins that end with the end of the point 1 on the real line.
From each of the two other points on the secant draw segments parallel to the one you just drew.
Here is how it looks on a picture.
If you have another fraction (5/7) draw 7 equal length segments on the second line (secant to the real axis). The parallel line from the 5th point will cut the real axis at the point 5/7
Dec 06, 2013 | The Learning Company Achieve! Math &...
I put on a 13 part show by the name of true justice at the end of episode 13 it was to be continued, why do you put on first 13 episodes and not the rest, after 13 now what
In some case Netflix may not have the licenses to show all episodes or seasons of a television show. This happens quite often when it's a new series.
You may just have to wait some time until it finally becomes available.
Hope that helps!
Sep 22, 2013 | Netflix
I need instructions on how to use the GE Ge 15107 24Hour Yard Stake Timer
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15107-Manual-eng-spn.pdf
Above is link to GE 15107 manual
This is a 15amp timer that can handle up to 1440 watts
How to set timer
Rotate center dial to set current time
Line up current time with triangle on inner part of dial
The timer dial shows nighttime hours on dark part of dial, daytime hours show on light part of dial
The timer dial rotates like a clock after it's plugged in
The outside edge of timer dial has 48 segments
Lift up these segments for times you want timer OFF
Segments down for timer ON
5c24d6c.jpgSegments up, timer OFF. Segments down, timer ON.
Segments in photo are on the GE 15207 timer
Oct 21, 2010 | GE 15107 24Hour Yard Stake Timer
Cannot set it.
773ea72.jpgImage shows Deihl timer >> notice that segments located at top of timer are moved inward. This is how you set on-off times. Segments pushed in cause timer to turn ON. Segments out, then timer is OFF. Each segment represents 15 minutes, so for 2 hours, you move 8 consecutive segments. To set current time, rotate dial until current time lines up with arrow..
If timer is not rotating, then it is not wired correctly, or it does not have power, or timer has gone bad.
Drawing of SPST timer wiring for 120Volt, 240Volt or 24Volt circuit.
Up-vote if this answer helped. Thanks for the feedback.
Oct 14, 2010 | Diehl TIME CLOCK- 120V 24 HOUR
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
New Color Wheel not the same as original part which is 7 segment
you got sent the wrong color wheel, You will definatly need a 7 segment whhel for your model.Your color index will be off with the 6 segment wheel and you wont be able to index it correctly
Apr 02, 2009 | Samsung HLN617W 61" Rear Projection HDTV
I have a rockchip mp3 player and it is not comp. with window v ho
1.Install avi converter that came with rockchip.
2 Open program
3 Press add button
4 Press source file
5.Enter video that you want to convert in source fiile box
6 Enter target file path e.g "my converted files "you might want to create a new file for this .
7.Click the scope box.
8.It is a good idea to break the video up into segments,because you can not pause the player for very long before you will have to play the video from the beginning this is really annoying especially if you were half way through watching it
9. The first segment should begin at 00 and the time duration should be maybe 15 -20 min long ,the next segment would start from either 15 or 20 ect ect ,you might end up with maybe 10 parts or so to your video
10.After doing this press the save button you will have to do this for each segment of video,you will end up with multple entries on the converter.
11. Press close button on second screen ,this will take you back to avi Converter screen you will have multiple entries on it.
12 .Press convert now button and conversion will start
13. While the file is beiing converted bring up the location were the converted ffile is going for example "my converted files "or the new file that you created for them to go to .
14.In the "my converted files" section you will see your video segment being converted .you MUST wait until a picture of the video appears inside the icon rather than a computer icon .Once this picture appears you must rename the segment e.g right click on the picture annd renanme e.g transformers 1 or 2 or 3 ect ect
15. Once you have renamed segment then go back to avi converter and press delete the progress might only say 13 or 14 % but do not worry about this as long as you have a picture in the icon then you have that segment .then press convert now to convert next segment
16 DONT FORGET TO RENAME CONVERTED FILES OTHERWISE YOU WILL LOSE THEM WHEN YOU CONVERT NEXT SEDGMENT
17.you can either wait until all have been converted or you can transfer tthem straight into player .
hope this helps .
Feb 15, 2009 | Digital Mind Corporation iQ Sound...
Don't understand how to edit a long DVD that was converted from VHS. Using Adobe Premiere Elements 3
The solution offered by the FixYa expert probably would have worked but was a poor solution. I needed help with a particular piece of software - Adobe Premiere Elements and the expert by-passed my software and told me I needed to convert my video using a different piece of software to which he/she gave me the URL. After paying for FixYa help and being very uncertain about the advice, I turned to Adobe and paid them for assistance. The Adobe tech support was excellent and they were able to pinpoint the editing problem that I had encountered. I had learned how to edit the beginning or end of a video clip but not how to delete segments within a video. One solution ended up being: 1. cut the video into segments with each segment beginning or ending with unwanted material; 2. delete unwanted portions from the shorter segments
BTW - I did not need to convert my video, as the FixYa expert had indicated. It was fine, just as it was.
One problem with the FixYa "expert" was that his/her written English was very difficult to understand. It appeared that English was not this individual's native language and that he/she needed better command of English in order to give any confidence to folks needing help.
Jan 14, 2009 | Computers & Internet
Take link ot of watchband
take it to a jeweler because if you do it your self your warranty is no longer valid
Jan 06, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
