Question about The Audio Players & Recorders
I accidentally plug in a 110V Companion 5 system into a 220V supply I am a technician I have a service centre for other products such as amplifiers and speakers,could you guide me to locate the fault
2 Suggested Answers
  • 127 Answers
SOURCE: I accidentally plug in a 110V Companion 5 system into a 220V supply I am a technician could you guide me where to locate the fault and what what componenents would be required to be replaced
The power supply is the fault. The power supply is dangerous to repair if you don't know how it work. I sugest to send it to an electronic repairer.
Posted on May 16, 2017
What will happen if inserted the 110v input d-link wireless router power supply to a 220v outlet? does my router busted or just the power supply?
Most likely you have damaged not only the power supply but also the D-Link wireless router unless the power adapter is a multi-voltage power adapter. Check the label on the power adapter and if the input voltage is a fixed 110 volt power supply you are in trouble.
You can try getting a 110v power adapter and connect it into the D-Link and if it works then you are lucky.
Dec 29, 2012 | D-Link DIR-615 Wireless Router
I accidentally plugged in my pulmoneb in a 220v outlet
plugging a 110v device into a 220v outlet is not likely, as the plugs are a different configuration. In the event that you somehow managed to do that, your device is probably fried, as that would be to much voltage. Hate to say it; but you are probably gonna need a new one
Nov 27, 2012 | DeVilbiss PulmoNeb Compressor Nebulizer...
My son accidentally plug a 110v bose 3-2-1 to a 220v outlet. What do you think is the damage? Do we still need to send it to a service center?
If you are lucky you would have lost the fuse on the sub woofer module which powers the whole unit. If not, yes you will need a qualified technician to look into the matter because its not a small offense to plug a 110 device into 220v.
Jul 06, 2011 | Bose 3 2 1 GSX System
I just bought a computer speaker but it's 110v and my computer is 220v. can i plug the speaker to the computer without damaging the speakers?
Hi ,
If it says it needs a AC 110V connection , you will fry at least the sub . Don't do it ! Connect the device to an AC 220 / 110 V transformer you can find on the net or in all specialized retail shops .
Best regards
Feb 03, 2011 | Bose Companion 5 Multimedia Speaker System...
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
Bose Companion 5 110v/220v short circuit
The fact that everything but the power amp is still working, it could be only a fuse protecting the output that needs replacement although this fuse is probably circuit-wise after the main fuse you have already replaced and could be soldered on the board. Worst case, the output modules are blown and require replacement and depending on the power level it may be worth repairing instead of replacing.
Most modern electronic devices can be set or adapted to line voltages from 100-240 Volts and a good percentage of the devices, using the common switched mode power supply don't need any changes made by the user since they can be inherently 'auto-ranging.'
Apr 04, 2010 | Bose Companion 5 Multimedia Speaker System...
Does the Bose companion 3 have an internal fuse?
Yes. The companion 3 system can be repaired for $75. Call Bose at 800-367-4008. They will also give you a new 1 year warranty.
Jun 19, 2009 | Bose Companion 5 Multimedia Speaker System...
Bose Companion 5 Down!
While I can not second guess your technician, perhaps the problem may not be that severe. The Bose Companion 5 is only on standby when plug (having no power switch) and therefore the power supply circuitry is the only one working. Chances are it will be only the +5VDC logic supply that is really turned on at that instant. All others would be OFF hence my belief that the problem may be limited to the PSU and/or part of the logic board. Perhaps you can suggest to your tech to test the logic board (motherboard) using an external +5 supply. All others can be be tested and repaired using component replacement.
Should you not be comfortable going this route, perhaps you best bet would then be to get in touch with Bose or their local representative.
You can try looking over the country here and the page will display a Bose contact information. Say the Philippines would be:
Eleksis Marketing Corporation
Unit 206 Fox Square Building
53 Connecticut Street
Northeast Greenhills
San Juan City, Metro Manila, 1500, Philippines
Tel-1: 632 724-9566
Tel-2: 632 724-7527
Fax: 632 724-0176
Email: Click here to send them an email
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Bose Companion 3 Computer Speakers
26 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
kbrowndo4u
Level 1 Expert
metsamehike
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
