Question about Vax Vacuums
Trying to find a detergent for a vax steam - Vax Vacuums
My vax is not producing steam both lights are on
Check your filters to see if they need cleaning.
Nov 03, 2016 | Vax Vacuums
Where do I add detergent to my vax VRS29M powermax 10 in 1 steam cleaner
usually in the water before adding that to the tank .
Feb 27, 2015 | Vax Vacuums
How do iput water in a vax hard floor advance+steam cleaner s3s+
look for a big knob that you can unscrew. When you locate this knob unscrew fully and add water......then screw tighten and you are ready to turn on appliance.
Dec 06, 2014 | Vax Vacuums
How do I put water in a Vax steam hard floor mop
Sep 30, 2014 | VAX Appliances Vacuums
Why is vax s7-a+steam mop steamer dripping water and cuts on and off
I managed to fix mine after a little effort. It was blocked well up in the nozzle into a small pinhole where the steam comes out of the 'small kettle' in the steam mop.
To fix:
  • take the blue side bit off by unscrewing the two small screws
  • Undo the screws inside (there are about 11)
  • Once these were undone there was two screws holding the nozzle cover.
  • After unscrewing these pull the nozzle cover of and scrape limescale from inside the small hole where the steam comes out
  • Put it all back together and it should work much better
You should only really do this if you are competent as there are lots of wires etc. and if your steam mop is not covered under warranty as messing around with it will void this.
Hope this helps :)
Jul 04, 2014 | VAX Appliances Vacuums
Vax steam mop pro
maybe if you set fire to it, you would get more steam.
May 13, 2013 | Vacuums
Vacuums Logo
21 people viewed this question
Top Vax Vacuums Experts
rugby prop
Are you a Vax Vacuum Expert? Answer questions, earn points and help others
