Question about Power Computers & Internet
My smart label printer power went out in the middle of printing a label. Nothing wrong with the labels or the power cord.
Tried unplugging and plugging in again and no change. I tried another plug and no luck. The cord looks in new condition. Any ideas?
    Top Expert:
  • Power Master
  • 41,663 Answers
An internal fuse may have opened.
Posted on May 16, 2017
  • Lisa Carroll
    Lisa Carroll May 16, 2017
    I don't see any internal fuse. Any other ideas?
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
After printing a label it advances too far wasting the next label
This is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Jan 03, 2014 | Seiko Instruments Smart Label 450 Thermal...
My Brother P-Touch QL 500 stopped printing and keeps blinking
Either the wrong printer is selected or the wrong size label inserted. Another possibility could be the incorrect size label in the format.
Sep 15, 2017 | Brother P-Touch QL-500 Label Printer, 300...
At the end of a set of labels, my 400 jammed so I had to take off the front section to clear the jam. When I loaded new Dymo labels, it now doesn't print. Not sure if when I took off the front...
Welcome to FixYa.
Reset the printer by doing the following:While the printer is on, unplug the printer power cord.Restart the computer.Plug back the printer. Make sure all connections are properly connected.Unload an reload the Dymo labels.Then restart the computer again.Try to print.
Thank you for using FixYa.
Jan 04, 2012 | Dymo LabelWriter 400 Thermal Printer
My Dymo Labelwriter 400 turbo will not print. The print error comes up and does not tell me what is wrong. When I take the labels out and reinsert them the labelwriter will not load I have to unplug the...
In most cases, problems are solved by checking whether the spools are firmly pressed against the label roll: This machine can be very picky. Many questions can be answered at the following site. http://global.dymo.com/enNZ/HowTo/LabelWriter_400.html
Chris Thrash
B52Computers
Jan 19, 2011 | Dymo LabelWriter 400 Turbo Thermal Printer
Smart LabelPrinter Seiko 440
The code between the labels indicates either you are using labels designed for another model or that it is thinking it has a shippinhg label opr some lareger type installed. IT is more likely to be the first option, you are usinjg the wrong coded labels
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Seiko Smart Label Printer Pro Thermal
Smart Label Printer 430
Delete it from Control Panel, unplug the USB cable, then reinstall the softwre.
Jan 05, 2009 | Seiko Instruments Smart Label Printer 430...
Hi, My Smart Label Printer 430 was working fine until I unplugged the back 2 cords to change the tape in it. How do I get it to print again?
unplug your Smart Label Printer (slp430) from your pc,
go into your control panel, then to add/remove programs.
remove the slp430 software then reboot your pc.
DONT PLUG IN YOUR SLP430 yet...
reinstall the software that came with the label printer.
follow on screen instructions.
plug power in for the printer
then attatch to your pc.
if this doesnt work let me know ; )
Printing every third labels ---> not every one:(
Sounds like the label height is set too high. Go into Printer Preferences in Windows and change the height dimension to match the size of the label you are using.
May 08, 2008 | Zebra S4M Thermal Label Printer
Smart Label Printer 240
Start with unplugging it and rebooting pc to see if it will reset itself
Nov 27, 2007 | Seiko Smart Label 240 Thermal Printer
Computers & Internet Logo
Top Power Computers & Internet Experts
waruna
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
