Question about Sony CDP-CX70ES CD Player
My cds are starting to skip all of the sudden.
Ive cleaned the lens to no avail. what can I do?
  • 6,784 Answers
HI, this will occur if the optics assembly stabilizers are worn. the tracking arm is supported by these stabilizers. they tend to ware overtime. you will need to replace the optics assembly asap.
Posted on Jul 25, 2009
Yamaha CDX 490 problem. CD skips in music. Hope you can help me. Best regards Preben Staunsbjerg Denmark
First, try other CDs to be sure the problem isn't with the particular CD you are playing. If it's just the one CD, try cleaning the CD with soap and warm water, then drying lightly with a soft cloth. If it has trouble playing ALL CDs, it the lens on the CD player may be dirty. This is especially likely if the device is in an area where it is exposed to cigarette smoke or heavy dust. If you're technical, the lens can be cleaned VERY GENTLY with a cotton swab dampened with a tiny amount of isopropyl (rubbing) alcohol. If you are not technical, you will need to have a technician clean the lens. There are also various lens cleaning kits available at your local electronics store or music store which have special lens cleaning CDs, many of which are effective.
Jul 17, 2011 | Audio Players & Recorders
My cd player skips
there are a few options
maybe your cd player is on an unstable surface and so the cd skips from vibrations or movements so you will need to put it on a stable surface free from movement or rumbles so that the cd player can read the cds without any interference.
Also maybe your lens is dirty or your cds are dirty or scratched, in which case her's what you can try:
1) buy a cd lens cleaning kit from a music shop or electronics store and clean the lens
2) but if the cd player is quite old then there may be a build up of dust and dirt inside so you will need to get it cleaned professionally
If the cds are dirty then clean using a soft cloth from the inside to the outside edge in a straight line
if the cds are scratched then buy new cds and treat them with respect. Make sure you don't put grubby fingers on the surface and try to handle them by just putting your finger through the middle hole and the outside edge with clean hands. and remember to put them back in the case and not leave them on the side or on the floor or stacked in piles
good luck
Jan 07, 2011 | Bose 901 CD Player
I bought a Radio Shack cd cleaner (cd w/little brush on it) to clean the lens of the cd player however the machine won't recognize the disc when inserted so I cannot figure out how to "play" it. Many of...
yes here is a simple easy way to get them to stop skipping, stick them in the freezer portion of your fridge, only if the cds have scratches on them, even the smallest scratch can cause a perfectly working cd player to make the cd skip, stick the cd in the freezer for about 15 or 20 mins and pull it out and play it, i have used this method for a lot of my video games as well and have never had to buy any "cd player cleaner cds" i hope this helps
Jul 16, 2010 | Sony CDP-CE575 5-Disc CD Changer
Yamaha CDC-765: sometimes skips when playing CDs
The problem is in the laser for sure. Try cleaning with a cd cleaning tool. It's the easiest solution because changing the laser is not always available solution.
Stelios.
Feb 21, 2010 | Yamaha CDC-765 5-Disc CD Changer
CDs skip
Hello
Ok, it sound to me that the laser lens which actually reads the cd's has some dirt particles on it.
There is a very cheap method of solving this problem.
Just go to any cd shop and buy yourself a decent laser lens cleaner disc, follow the instructions and you should be set.
Kind regards
Andrea
Dec 13, 2009 | Technics SL-PD6 5-Disc CD Changer
Cd player is skippping - I have cleaned the cds. still skipping. It is a bose wave radio single cd player.
Hello my friend,
I suggest to test with many different CDs, if it's still skipping in all CDs. i will say that it's a lens issue, in this case you buy some CD cleaner which has some special lotion which clean the lens. but if this doesn't help also, at this time i will say that the lens needs to be replaced and i hope that you device is still under warranty because the repair will be free for you.
Best Regards,
Oct 30, 2009 | Bose & Wave& Music System
Cds dont load and tracks will skip during song play
It is clear symptoms of bad optical laser or dirty optical lens.
Please put lens cleaning CD in player, play that CD to clean dust on optical lens surface. If that helps, fine or replace optical laser block in player.
I can provide you optical lens part number, please confirm is it Sony CDP-CX153 cd player or any other model.
Thanks.
Oct 27, 2009 | Sony CDP-CX153 100-Disc CD Changer
Tascam CD-450
re shock mount it in case blow out all the dust
Jan 14, 2008 | Tascam CD-450 CD Player
Skipping
If you go out and buy a cleaning disc it may help. You should really clean a car cd player at least ounce or twice every 6 months to get the best sound and play out of the unit. You can pick these disc up at any walmart , kmart , or computer store. Hopefully this can help you out
Dec 18, 2007 | Kenwood KDC-MP228 CD Player
Lens Knocking Against The CD - All CDs skip or diginoise then fail.
Take the small back cover off and take some electrical grade contact cleaner and spray all around the lens area, that worked for me.
Mike
Jul 29, 2007 | Sony CDP-CX400 400-Disc CD Changer
Sony CDP-CX70ES CD Player Logo
83 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
