Question about Johnson Boating
The model# of a johnson 50hp 2 cycle boat motor with serial# G3032381?
SOURCE: Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Posted on Jul 25, 2009
Editor925
  • 285 Answers
SOURCE: oil mixture for a 70 hp Johnson boat motor?
If it is a 2-stroke motor than gas:oil ratio should be 50:1
Posted on Sep 04, 2009
SOURCE: where do i put in hydraulic fluid in a johnson 225 boat motor
WHERE DO I PUT HYDRAULIC FLUID TO MAKE MOTOR TILT ON A JOHNSON 115 HP 2000 MOTOR
Posted on Apr 23, 2010
  • 50296 Answers
SOURCE: where is the serial number on mercury 115hp 6 cylinder boat motor
http://www.marineengine.com/mfr/mercury_models.html
Posted on May 01, 2010
  • 214 Answers
SOURCE: Hi, whats the oil capacity for an ingersoll rand
Below is the procedure for COOLANT change including amount needed.
SSR Ultra Coolant (Standard Factory Fill)
SSR Ultra Coolant is a polyglycol base coolant. Change
Ultra Coolant after every 8000 hours or every two years,
whichever comes first.
In addition to the tools normally found in any reasonably
equipped serviceman's toolbox, the following items
should be available at the work site:
1) Suitable drain pan and container to hold lubricant
drained from unit.
2) A quantity of proper lubricant sufficient to refill the
compressor.
3) A minimum of one replacement coolant filter element
of the proper type for the unit to be worked on.
There is a coolant drain valve on each compressor. It is
located on the bottom of the separator tank.
The coolant should be drained soon after the compressor
has been shut down. When the coolant is hot, the
drainage will be more complete and any particles in
suspension in the coolant will be carried out with the
coolant.
Hot coolant can cause severe injury. Use care when
draining separator tank.
To drain the unit, place drain pan under drain valve. Open
drain valve to start drainage. After draining is complete,
close drain valve.
After the unit is drained and a new coolant filter element
is installed, refill the system with fresh coolant through
the filler cap on the side of the separator tank. Bring the
receiver level of coolant up to the top of the sight glass.
Replace the fill cap. Start the compressor and allow it to
run unloaded for a short time. The correct coolant level is
at the midpoint of the sight glass with the unit running in
the "UNLOADED" mode. If the level is not near the
midpoint, stop the compressor and allow all pressure to
relieve from the system. Open the fill cap and add more
coolant.
50 hp (37 kw).....................3.4 gallons (12.9 liters)
Coolant fill quantity
! WARNING
Use care when near this area.
Use only recommended
coolant.
Read instruction book
before servicing.
39543921
run unloaded. The coolant level should now be near the
midpoint of the sightglass.
DO NOT OVERFILL THE MACHINE. Over filling will
affect separation and carryover down stream.
Posted on Jan 21, 2011
Carbies on 50hp Johnson outboard fill with oil when left standing for extended times
2 stroke , excessive oil in mix and it is settling out after the fuel evaporates off
4 strokes the unit should be left in the drive position when not used
Dec 16, 2017 | Johnson Boating
I have a 50hp Johnson motor. I am unable to raise the motor with the electric switch, ( it does work letting the motor down) my question is, Is there a way to lift the motor manually?
Yes there is a way to do it manually. You will have to bridge the post on the selinoid using a screwdriver. Touch the 2 post on the selinoid with a screwdriver. Or replace the selinoid to fix it correctly.
Aug 04, 2017 | Electric Boating
What year and other information can you tell me about a Johnson Outboard motor model 50ESL73R Serial # E3817581
Model # shows it's a 1973 year, 50 horse power. 2 stroke engine with 50 to 1 fuel mix.
Apr 27, 2017 | Johnson Boating
What year is my 50hp Johnson mototr serial # J5667456
http://www.iboats.com/basics/serial_number_year.html
Nov 07, 2015 | Boating
Serial number J3062276 model 6r 69m what year is this Johnson boat motor and where is best for parts
a johnson dealer will be the best place for parts and you can find them by going on line to johnson outboards and opening the dealer distribution page
you may be able to get the year for the motor from the same on line contact page
Jul 12, 2015 | Boating
Boating Logo
27 people viewed this question
Top Johnson Boating Experts
kj henriksen
kj henriksen
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
