Question about Johnson Boating
What is the model# for johnson 50hp 2 cycle motor with serial#G3032381
  • 214 Answers
SOURCE: Hi, whats the oil capacity for an ingersoll rand
Below is the procedure for COOLANT change including amount needed.
SSR Ultra Coolant (Standard Factory Fill)
SSR Ultra Coolant is a polyglycol base coolant. Change
Ultra Coolant after every 8000 hours or every two years,
whichever comes first.
In addition to the tools normally found in any reasonably
equipped serviceman's toolbox, the following items
should be available at the work site:
1) Suitable drain pan and container to hold lubricant
drained from unit.
2) A quantity of proper lubricant sufficient to refill the
compressor.
3) A minimum of one replacement coolant filter element
of the proper type for the unit to be worked on.
There is a coolant drain valve on each compressor. It is
located on the bottom of the separator tank.
The coolant should be drained soon after the compressor
has been shut down. When the coolant is hot, the
drainage will be more complete and any particles in
suspension in the coolant will be carried out with the
coolant.
Hot coolant can cause severe injury. Use care when
draining separator tank.
To drain the unit, place drain pan under drain valve. Open
drain valve to start drainage. After draining is complete,
close drain valve.
After the unit is drained and a new coolant filter element
is installed, refill the system with fresh coolant through
the filler cap on the side of the separator tank. Bring the
receiver level of coolant up to the top of the sight glass.
Replace the fill cap. Start the compressor and allow it to
run unloaded for a short time. The correct coolant level is
at the midpoint of the sight glass with the unit running in
the "UNLOADED" mode. If the level is not near the
midpoint, stop the compressor and allow all pressure to
relieve from the system. Open the fill cap and add more
coolant.
50 hp (37 kw).....................3.4 gallons (12.9 liters)
Coolant fill quantity
! WARNING
Use care when near this area.
Use only recommended
coolant.
Read instruction book
before servicing.
39543921
run unloaded. The coolant level should now be near the
midpoint of the sightglass.
DO NOT OVERFILL THE MACHINE. Over filling will
affect separation and carryover down stream.
Posted on Jan 21, 2011
SOURCE: How and where do I remove the gear linkage so I can remove the leg from a Johnson 115hp outboard motor Model J115PXSRC serial number 05037458
Please contact me at +270782863573 Thank you,
Ben van Schalkwyk
Posted on Jan 10, 2012
goldbill
  • 184 Answers
SOURCE: 72 johnson 50hp will not cool
If your water pump is OK, check the thermostat by removing it (under a 3 screw cover on the cylinder head) and starting the motor. You should get a geyser of water from there. Before it (the water) gets hot, put your thumb over the geyser and bleed out any air/exhaust. If you get lots of bubbles you have a bad head gasket, or base gasket or exhaust baffle/ side plate. No way to tell which, so start with the easiest (the baffle) and work to the hardest.
Posted on Jul 23, 2012
davesw3713
  • 32 Answers
SOURCE: I have a 50hp johnson outboard the motor is turning over but I dont seem to get a spark to the plugs
would this help
Primary cause of hard cold start: operator error.
Open gas tank vent, pump primer bulb until it is firm, raise hi-idle lever full up, push the key in and hold it in while turning it to "start".
If you can flood your engine with the primer bulb, then your carbs need rebuilding. Pump the bulb until it is firm - that fills the carb bowls - they have a float valve that closes when full. This is true of every carbureted 2-stroke outboard ever made.
"Pumping the throttle" is useless - these are not automotive carburetors - all it does is open and close the butterfly valves.
Your motor does not have conventional choke plates; instead it has a primer solenoid, which opens a valve and allows fuel to drain into the cylinders to richen up the mixture for cold starts. You should hear the solenoid "click" when you push the key in.
Bad compression leads to hard cold starts - you should have at least 100 PSI in all cylinders, and the lowest needs to be within 5% of the highest.
If you have good compression and spark on all cylinders, the primer solenoid actuates, and the fuel line holds pressure, then you need to remove your carburetors, dissasemble, soak overnight in carb cleaner, blow out passages with compressed air (or aerosol carb cleaner), reassemble with new kits (including new o-rings, gaskets, and float valves & seats), reinstall, link & sync, and adjust slow-speed mixture
Posted on Mar 15, 2013
AndrexT
  • 20956 Answers
SOURCE: what kind of gun is a ives johnson arms and cycle works with serial#65851?
It is Iver Johnson, not Ives Johnson. You always need to know the calibre, and that should be marked on the barrel.
There are lots of pictures here.
http://www.bing.com/images/search?q=iver%20johnson's%20arms%20and%20cycle%20works%20revolvers&qs=n&form=QBIR&pq=iver%20johnson's%20arms%20and%20cycle%20works%20revolvers&sc=0-37&sp=-1&sk=
Info Forum here on serials
http://www.thefirearmsforum.com/threads/iver-johnson-serial-number-help.141829/
Still in business, but no support from older weapons
http://www.iverjohnsonarms.com/
Pricing here, but you have to know the model
http://bluebookofgunvalues.com/Gun_Values/Manufacturers/IVER_JOHNSON_ARMS_CYCLE_WORKS?id=IVER_JOHNSON_ARMS_CYCLE_WORKS
and finally Wikipedia information on the company and weapons produced. Let me know if you need anything else?
Iver Johnson Wikipedia the free encyclopedia
Posted on Dec 24, 2015
Carbies on 50hp Johnson outboard fill with oil when left standing for extended times
2 stroke , excessive oil in mix and it is settling out after the fuel evaporates off
4 strokes the unit should be left in the drive position when not used
Dec 16, 2017 | Johnson Boating
I have a 50hp Johnson motor. I am unable to raise the motor with the electric switch, ( it does work letting the motor down) my question is, Is there a way to lift the motor manually?
Yes there is a way to do it manually. You will have to bridge the post on the selinoid using a screwdriver. Touch the 2 post on the selinoid with a screwdriver. Or replace the selinoid to fix it correctly.
Aug 04, 2017 | Electric Boating
I have a Iver Johnson 12ga double barrel with 30" barrel's s/n 28586 How old is it and What is the Value?
These will all help you.
Iver Johnson's Arms & Cycle Works - American Firearms
www.american-firearms.com/.../Iver%20Johnson's%20Arms%20.../Iver%20Johnson's...
  1. Cached
  2. Similar
Aug 7, 2011 - Single top latch, 100'000 were manufactured in 1894, serial number without letter prefix, marked on the top of the barrel rib. IVER JOHNSON'S ...
*IVER JOHNSON SERIAL NUMBERS ' The Firearms Forum
www.thefirearmsforum.com > ... > The Ask the Pros & What's It Worth? Forum
  1. Cached
  2. Similar
Jan 11, 2012 - 15 posts - ‎10 authors Is the gun large frame or small frame, hammerless or a hammer gun? ... I have a Iver Johnson Top Break 5 shot hammer gun. ... I just purchases an iver Johnson hammerless 5 shot top break revolver. Iver Johnson Serial Numbers 6 posts 26 Jun 2016 Iver Johnson Serial number help 15 posts 1 Nov 2014 Old Iver Johnson shotgun 12 posts 10 Nov 2011 Need Info on Iver Johnson Hammerless Revolver 15 posts 13 Apr 2006 More results from www.thefirearmsforum.com
Blue Book of Gun Values - IVER JOHNSON ARMS & CYCLE WORKS
bluebookofgunvalues.com > Gun Values
  1. Cached
  2. Similar
IVER JOHNSON ARMS & CYCLE WORKS gun model and pricing information.
Iver Johnson Arms - M1CarbinesInc.com
www.m1carbinesinc.com/carbine_ij.html
  1. Cached
  2. Similar
Introduction to Iver Johnson, Iver Johnson's Arms, & Iver Johnson's Arms & Cycle .... With the exception of the D-Day Carbines the serial number on Iver Johnson ...
manufacture date of Iver Johnson revolvers based on serial number ...
www.rimfirecentral.com > Other Rimfire Guns > Misc -- Other Rimfire Rifle Brands
  1. Cached
May 17, 2016 - 14 posts - ‎3 authors There is a serial number listing for the Iver Johnson SuperShot 22 Top Break Revolvers in W.E.Goforth's book/reference, "Iver Johnson Arms ...
Iver Johnson - Wikipedia
https://en.wikipedia.org/wiki/Iver_Johnson
  1. Cached
  2. Similar
Iver Johnson was a U.S. firearms, bicycle, and motorcycle manufacturer from 1871 to 1993. .... William McKinley in Buffalo, New York on September 6, 1901 with an Iver Johnson .32 caliber Safety Automatic revolver (serial number 463344). Iver Johnson 12ga Google Search
Nov 30, 2016 | The Optics
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
I have a 40 s Johnson seahorse td20 with serial number 63191 , and I was wondering what year model is it? I gave 280.00 for it, did get a good deal ??
the serial number is not consistent with johnson serial numbers as all have 2 letters followed at the end by 2 numbers which indicates the year of manufacturer 9 ( ft17598 indicates it was mahe in 98)
There are pages on the net explaining when a serial number is used but it must be old as johnsons have used model numbers for identification since 1960's
probably better if you take it to a johnson service dealer as they may have the johnson factor list for serial numbers as you will have to identify it to get parts
go google and type in manufacture date of 40s johnson td 20 outboard serial number 63191
if that shows no results just cahange some words in the search
Jan 07, 2016 | Boating
What year is my 50hp Johnson mototr serial # J5667456
http://www.iboats.com/basics/serial_number_year.html
Nov 07, 2015 | Boating
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Year model serial number
1978 It is in the model on an Evinrude. 6804.... 6 HP.....1978
Jul 22, 2014 | Clymer Evinrude/johnson Manual 2 Stroke Ob...
Boating Logo
27 people viewed this question
Top Johnson Boating Experts
kj henriksen
kj henriksen
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
