Question about Pool & Spa
)would like a safe alternative to alendironic acid ( to maximise absorption of calcium) Thank you
  • 923 Answers
I have studied about nutritional supplements ... a lot. What kind of calcium are you talking about? Is it calcium CITRATE, which is one of a VERY FEW TYPES that the human body can actually absorb? Are you battling osteoarthritis?
Posted on May 16, 2017
Dangers of lemon juice
Although lemon and lemon juice are well known as they are rich in vitamin C and if you drink the lemon juice in the morning will helps you in weight loss but there are several other problems that you may face when you drink them.
Here are some of the harmful effects that you may see by drinking lemon juice :-
  • It can cause the teeth to get unhealthy : - As our teeth needs good dental care and food that are rich in calcium to keep your teeth healthy. But drinking lemon juice may hamper all your efforts because the acid present in the lemon can eat all the enamels of the teeth that results in unhealthy teeth.
  • It can also increase the absorption of iron in the body :- Due to the present of citric acid and ascorbic acid present in the lemon it cause the increase in the absorption of iron.
  • There are many more things that can happen to you by drinking lemon juice daily.
May 15, 2014 |
Filters get dirty in one day
It sounds like the filters have clogged with oils or have calcium deposits. You'll need to soak them in a dishwasher detergent (cascade) overnight to cut the oils, rinse well, let dry, then put them in 4-1 water- acid solution to dissolve the calcium. You can also do this part with a watering can somewhere where the acid won't hurt anything.
Dec 17, 2013 | Jandy Pool & Spa
Are there different types of calcium supplements?
Yes. There are actually two different forms of calcium supplement: calcium carbonate and calcium citrate. Calcium carbonate is the cheaper one of the two and should be taken with food. Calcium citrate can be taken on an empty stomach and is absorbed well for people who have low levels of stomach acid.
Feb 04, 2013 | Health & Beauty
How much bicarb of soda do i use to descale my bosch tassimo
Sodium bicarbonate is not a descaling product. It makes a nice minimally abrasive cleaning agent when mixed as a paste. Sodium ions will exchange with calcium in a water softener when the calcium is dissolved in water. Once the calcium salt (calcium carbonate) forms, it doesn't go back into solution in a neutral or basic environment. A bicarbonate solution will be basic.
Descaling requires an acid. The Tassimo products say "Do not use vinegar" (acetic acid). I suspect they use citric acid in their descaling product. You can try the lemon-flavored Kool-aid (the version packaged in the envelopes that needs a sweetener added when it's a drink). Mix 1 tablespoon of the powder in 1 pint of water. However, you'll need to make more than a pint of the solution since you need 500 ml of liquid per cleaning cycle. (1 pint is ~473 ml.)
I hope this helps.
Apr 24, 2012 | Bosch Tassimo TAS4011GB Coffee Maker
Ma dell vostro a860 have problem(xp operating system) that was, open my computer or internet it will maximise & minimise automatically. please solve my problem. thank you.
Try to boot in safe mode. And check your system
To enter safe mode
press f8
under advanced start up options
select safe mode enter
check once and revert back
May 17, 2011 | Dell Vostro A860 Notebook
There may be a calcium build up on the fingers, and just cleaning them will not remove the calcium. I would disassemble filter again, then give the fingers an acid bath. Mix about 50 -50 muriatic acid and water and let elements sit in a bucket with the mixture for 15 or 20 minutes, then reassemble and see if this fixes problem. (the quick test is to let the pressure get real high, than add some acid to the skimmer and see if that lowers the pressure at all)
Jul 15, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
Calcium build up removal????? Our water has a lot of calcium. Lately, my dishes are not getting cleaned and it appears there is a lot of calcium built up. What is the best way to remove it?
add dishwasher salt if you live in a hard-water area to prevent calcium build up, and try adding a litre of pure lemon juice to remove the initial crusting, as the calcium is highly alkaline, and the lemon juice, being acidic, neutralises it.
Nov 06, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Pool & Spa Logo
27 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
