Why does my washer have all the lights on and make a buzzing noise when i use the machine
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
http://www.appliancerepair.net/washing-machines-forward.html
Mar 08, 2013 | Roper Washing Machines
Machine is not washing, spinning or draining
has someone interfered with the inlet tap. The buzzing is normally a sign that the appliance is trying to take water but tap is off.
Mar 29, 2010 | Zanussi ZWF14070 Front Load Washer
Washer makes a buzz noise shuts off displys do and fl
I used the recommendation of removing the soap dispenser area on top of the machine, under that area is a thin green nylon cord that when pulled will release the lock on the door of the machine and open it. after the door was opened it reset the machine and now is working fine.
Dec 28, 2009 | Maytag MAH6700AWW Neptune Front-Load...
I have a neptune washer that makes a buzzing type noise when I hit the start button? from motor area. The belt and pulley into the unit turns freely. I did get it to start and the barrel did rotate then...
The buzzing noise is probably an electrical relay that controls the motor. They have a spring assembly on an arm. When you energize it it creates a magnetic field and pull the arm down into contact and starts the current flow to the motor. If it's buzzing, the relay is probably bad and need replaced.
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Me Estate washing machine, when started fills to specified water level then, it makes a buzzing noise then the buzz quits and nothing happens. Machine won't agitate or drain, just buzz then buzz quits.
sounds like you have a problem with your water supply to washer. the buzzing noise sounds like it's the valve opening to receive water but nothing going in. check supply hoses and water taps
Jul 14, 2009 | Washing Machines
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
May 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not begin cycle
The buzzing noise sounds like the water valve calling for water.. check your water suppy to washer... dont sound like its getting any water or theres a blockage kinked hose ect.
Sep 02, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
