Question about Coffee Makers & Espresso Machines
Instructions on how to operate the ALMA ESE POD MACHINE
I want to know how does it work and if the coffee flow stops automatically.
SOURCE: operating instructions
I have this manual (CM500) and can scan/email it to you if you send me your email address...also I am looking for a replacement lid for my carafe for this machine if anyone is looking to get rid of theirs!
Posted on Feb 20, 2009
EsWorld
  • 1618 Answers
SOURCE: Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
Posted on May 31, 2009
  • 19 Answers
SOURCE: i have a venus vw600b front loading washing
NOTHING TO WORRY PUT YOUR WASHABLES INTO IT AND CLOSE THE DOOR AND SET TIMER ACCORDING UR NEED
Posted on Aug 05, 2009
NiftyInsight
  • 15 Answers
SOURCE: unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
Posted on Feb 21, 2010
tgmusicgirl
  • 92 Answers
SOURCE: The water will not go through the pod to make the coffee
This sounds like the pin used to puncture the K-Cup is clogged with something...
since a K-Cup is not used when making conventional Tea, this sounds like you need to remove the k-cup holder, which, by the way is a 2 piece unit on the B70 models... and I believe is the same for yours...
the lower third of the k-cup holder snaps off... revealing a better look at the Piercing Pin.
Looking at the sharp pin inside the holder, you should notice that it IS hollow... and you need a metal... not plastic coated paper clip and get it through the piercing needle.
I think that will do it...
Posted on May 18, 2010
We have a Krups Nespresso machine that cuts out within seconds, even with no pod in place. It works by holding the button down constantly but could this damage the machine?
To programme the quantity you would normally hold the button down continuously for as long as it takes to fill your cup to the required level. Next brew you make should require a single touch & release it should then flow through as much water as the previous cup and then stop automatically. If it's not holding the programme I can't see any harm in holding the button down until the cup is full.
Oct 10, 2016 | Krups Coffee Makers & Espresso Machines
Our coffee machine is continually beeping and the water flow will not flow automatically, is there a reset button or something
It's beeping because it's in programming mode. Usual reason with a machine of this age is that the touchpad has failed. Water gets into the touchpad membrane after a while, which makes the controller think a button has been pressed. If it thinks the STOP button is being pressed/held for more than 5 seconds, it goes into programming....
To confirm: Remove drip tray, take lid off controller box and unplug one of the flat plugs from the keypad (there will be two long thin plugs next to each other, and probably a space or two for extra plugs). When you get the correct one, the beeping will stop and the machine will resume normal operation on the working keypad.
Oct 23, 2014 | Faema Smart A2 Automatic Espresso Machine...
I cant get my Gaggia Classic to work with pods
You need to use the single-serving size one-hole basket, not the double, with the diffuser valve seated beneath the basket. Then the Illy ese pod should be inserted with the decal facing up. Finally, and most importantly, when you lock the filter assembly into the machine, you need to close it firmly. Brown water can mean that the basket assembly is not sealed in tight enough.
Sep 07, 2014 | Gaggia Classic Espresso Machine
Can I adapt a Francis francis x1 to take ese pods?
My X1 came with an ESE pod holder and a ground coffee holder so they are definitely available.
Dec 02, 2012 | FrancisFrancis! Coffee Makers & Espresso...
When i place pod into machine it doesnt have any water or coffee come through when i switch it on
A few initial steps:
  • Insure that the water reservoir is full, and that the machine is plugged in.
  • Check the water inlet tube for kinks.
  • Ensure that you are using the correct portafilter or insert for ESE pods.
Here is a link to the manual.
Krups contact:
Phone: 1-800-526-5377
Monday through Friday 8:00 AM to 9:00 PM EST
Saturday 10:00 AM to 2:00 PM
Mar 03, 2011 | Krups XP4030 Espresso Machine
The coffee spout is pouring into the coffee pod collector
I have the sameproblem, I suspect something is blocked but I don't know how to remove the spout????????? Please helP!!!!!
Feb 08, 2010 | Nespresso C100B Essenza Single-Serve...
I have the Keurig Gourmet Deluxe Home Brewing System #B60 When the pod is in place with the cover down the water won't come out while brewing. It will not make a brewed cup of coffee. If I remove the pod...
Check that pod has a punctured hole on BOTH ends.. If the bottom or to wear not punctured this will happen with most Keurigs.
Replace the pod holder if defective.
May 18, 2017 | Keurig Coffee Makers & Espresso Machines
May 30, 2009 | FrancisFrancis! X1 - Stainless Steel...
Senseo machine has started producing very weak coffee
I don't know if you've tried this, but it works like gangbusters for me. I use non-senseo pods with the 2-pod holder, and they're too big for the 1-pod holder but not quite big enough for the 2-pod one.
I would frequently end up with a lousy, weak cup of coffee, and after a little investigation I deduced that water was flowing into the pod holder and AROUND the pod, without going THROUGH the pod directly. The name-brand senseo pods fit perfectly, and always produce a strong cup, even if I don't like their coffee, and it's because there's such a tight seal between where water flows in and where it flows out.
Simple solution: Put your pod in with the flat part facing up, and the bulgy part facing down. Press it down hard into the 2-cup holder. Run a little HOT tap water, and lightly wet the surface of the pod--not so much water that the pod starts floating in the holder, but enough to get it soggy. Then make your cup of coffee. The water will flow through the pod first, and kind of like siphoning gas through a hose, once it's started going through the pod it won't stop. Instant awesome cup.
Oct 24, 2008 | Philips Senseo HD-7810 Coffee Maker
XP2070 can no longer get the right amount of espresso when using ESE pods.
The amount of liquid is programmable but you have to have a working flow meter. Do you get the right amount when doing a single or double espresso? Read the instructions to reprogram the amount of liquid when using the ESE pods which are most likely single shots. If the memory functions does not work then most likely you have a faulty flow meter which is not too difficult to replace and costs < $20,
Aug 04, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
