Kenwood KDW 60X13.No error code but will not function.Starts a cycle but won't finish. Randomly unable to select a function Goes dead then comes back on. Bleeps occasionally.
  • 105 Answers
SOURCE: I have a kenwood dishwasher
means the machine has flooded internally
remove machine from cavity and fix leak on machine
Posted on Feb 24, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Indesit WIE 1375 error code?
This is a pressure switch error.
It still thinks the machine is empty because the switch sees no pressure (simple dip tube).
But this may be as simple as a vent hose come off.
To check,
First isolate supply, then remove screws at top rear of the machine.
Slide the lid rearwards, and remove.
The small hoses should go to the drawer area, and the pressure switch will sit at the end of one of them.
If there are any rips or damage to a hose it need replacing.
Check all hoses are where they should be.
If this doesn't work, please ask here again so I can troubleshoot further.
Thanks for using Fixya!
Posted on Jun 22, 2008
SOURCE: SMEG DI 612CA. Dishwasher
Pisss!!! Comin from my asss!!
Posted on Jul 24, 2008
SOURCE: battery goes dead randomly ,other times starts right up
I had the same problem, every 3-4 months the battery was dead. Found to be the computer staying in a self diagnostic mode that was slowly draining the battery.
Cheers
Posted on Nov 06, 2008
SOURCE: washing machine fault
im having the problem now with my daewoo that every time i put a wash on its giving me a H6 message error
Posted on Dec 17, 2009
Key board not working COPIER>FUNCTION>CLEAR>ERR.
Do you mean the LCD display is not responding , or that the number keys do not work, or both? I suspect that the keypad and display do work but your real issue is that you cannot enter service mode to reset an error code. Entering service mode can be a little tricky on that model. Hit *(Add. Functions, not the * on the keypad). So , to review, * then the 2 and 8 key simultaneously, then * again will get you into service mode. A screen will pop up that says Copier and other stuff. Select Copier. Then hit function tab at top of display. Then Select Clear (CLR) Then Error(ERR) then hit ok at the bottom of display. Then cycle power, if the error resets, you are done. If the error comes back, you need a part. Important----do not randomly clear any other items in service mode. You can cause a lot of problems if you do. Only clear that error code. Hope that helped. If not, you need to call a technician.
Sep 03, 2014 | Canon Ir 3300 Black & White Copier
I have GE GLDT696TSS. The dishes are not clean and one time noticed water leak from the back of the washer.
You should check the water outlet - probably discharges into your sink through a garbage disposal - the water outlet is likely plugged and water can not discharge down the sink. You can remove the hose and clean it out.
Apr 06, 2014 | GE GLDT696TSS Builtin Dishwasher
My frigidare affinity shuts down mid cycle , and has to be restarted many times in order to finish a load of clothes
Remove top of washer by removing screws in back of top. You should see the tech sheet. Use this to retrieve any error codes.
A common problem with these is a bad door switch. (The part the strike goes into. If this is the case you should come up with error code for it.
Mar 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Elctrolux dishwasher won't start, display won't light and it randomly beeps
Check continuity of the 4 small wires that connect to the control panel to the control board. They seem to break where they flex for the door to open and close.
Jul 25, 2012 | Electrolux EWDW6505GS Fully Integrated...
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
