Where can I find auto on my menu - Televison & Video
Auto adjust in progress
1. Push the menu button at the front side of your Dell monitor. The icon looks look like a miniature version of your monitor.
2. Push the menu button again. This will exit the monitor menu and launch the OSD (On-Screen Display) menu.
3. Use the down arrow button on your monitor to select "Factory Reset."
4. Push the menu button.
5. Use the down arrow button to select "All Settings." Press the menu button to save changes.
6. Push the menu button twice to exit from the menu. Your Dell monitor will go back to its factory settings default, and its auto-detect feature will be disabled.
Oct 10, 2014 | Dell E171FPb 17" TFT LCD Flat Panel...
Radio locked cant adjust
Can you hit
MENU (opens the menu)
24 and MENU (opens menu item 24, Auto-lock)
0 and MENU (sets auto-lock off and confirms)
EXIT
Auto-Lock locks up the keyboard to prevent accidental frequency changes. It allows for transmission with the PTT.
Jan 11, 2014 | Baofeng UV-5RA Dual Band Transceiver
Auto program menu code
you do not code for auto program , you need only go to the MENU, and select auto program
God bless you
Jul 18, 2013 | Panasonic Televison & Video
I can not turn off auto demo
To stop auto demo, press the MENU button, and select auto demo by pressing the up/dpwn buttons, and turn it off by pressing the left/right buttons. Press the MENU button to finish.
Dec 12, 2010 | JVC AV-65WP55 65" Rear Projection...
HOW TO ADJUST SCREEN BRIGHTNESS
on the bottom right corner of your monitor you should see 6 buttons starting from left to right e auto menu power
if the auto adjustment is not giving what you want go into menu and adjust it from there
menu menu then >
Aug 17, 2010 | Acer V193w LCD Monitor
My auto configuration menu on the monitor keeps popping up and cannot get it to stop what can I do?
auto configuration menu stays on monitor screen constantly while trying to use pc for normaluse.
May 20, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
THE CAMERA GOES DEAD VERY SOON WHEN IT TURNS ON. IT HAS GOOD BATTERIES.
Hi, I've scoured the 3 page manual and come up with this.:-
There is nothing wrong with your camera. The camera has a built-in power saving
feature that turns the camera off after 30 seconds of inactivity (default setting) to
conserve battery power. The auto off time setting can be changed in the set up menu.
Changing the Auto Off Time Setting:
1. Set the camera to Camera Mode.
2. Press the Menu button to display the main menu.
3. Press until the Setup is highlighted.
4. Press to enter the Setup submenu.
5. In the Setup menu, press to highlight “Auto Off Time”.
6. Press to enter “Auto Off Time”. Press to highlight the time you want.
7. Press the OK button to save your selection.
Hope this helps
Mar 05, 2010 | Concord Camera Eye-Q 4060AF Digital Camera
There are buttons on the front of the monitor. Why
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
Jan 27, 2009 | Acer X193W LCD Monitor
Sony trinatron has no menu control, can't auto add channels
YOU NEED TO GET INTO THE CONSUMER MENU AND ACTIVATE THE AUTO PROGRAMM MODE. I BELIEVE WALMART CARRIES A UNIVERSAL SONY REMOTE WHICH WILL ALLOW YOU INTO THE MENU.
APGONZO
30 YR SERVICER
Jan 11, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Auto adjustment?
Press and hold the Menu button until the menu disappears - and you're OSD will magically unlock.
May 11, 2008 | Samsung SyncMaster 913N 19" LCD Monitor
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
