Question about Kenmore Washing Machines
Replacing the fabric softener reservoir
I'm not sure how to raise the top of my washer in order to replace the fabric softener reservoir.
  • Anonymous Mar 19, 2014
    THE RESERVOIR FOR THE FABRIC SOFTENER DOESNT DRAIN
  • 42 Answers
the above image should explain very clearly how to access the softener dispenser. please make sure to replace any washer if present already(don't know your model and the machine in the image might not be exactly yours)
cheers
Posted on Jul 25, 2009
I have no water to fabric softener dispenser I
Google Neptune TL Washer FAV6800AWW
You can get the FAV6800A/FAV9800A Service Manual and get into Service mode and turn on the Cold Water Inlet valve and the Fabric Softer dispenser valve and see if water flows to the Softer reservoir. You may need to replace the dispenser valve.
Pic below. Post in the other forum it's easier to work the issue at a true DIY forum.
Mar 12, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Fabric softener dispensor does not empty
For the FAV6800A or FAV9800A:
If you have no water flow to the Softener dispenser or Bleach dispenser see if you can turn the dispenser valves on Service Mode and verify water flow to the reservoirs.
Enter Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the
Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the Fabric Softener dispenser water valve. Did you hear the solenoid hum? If so we will now need to turn on the Cold Water Inlet Valve and see if water flows to the dispenser.
Now press the Spin Only key this will turn on the Cold Water inlet valve after 5 seconds press the Off key. The washer will unlock. Check to see if water did flow to the fabric dispenser reservoir. If you heard the Fabric dispenser valve hum then most likely 120VAC was applied to the solenoid. If water did not flow then the Fabric dispenser valve is stuck closed if you heard it hum.
The Bleach/Fabric dispenser water valve is an assembly and is not repairable you have to replace.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Fabric dispenser solenoid.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price try appliancezone.com…
You can remove the Fabric Softner to clean see page 33 of the Service Manual…Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Apr 06, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Gold washer throws F3 and F4 codes
The problem with the fabric softener not dispensing is not likely related to and F03 error code due to the washer not draining.
For the dispenser problem, I recommend that you pull the dispenser drawer out and clean it thoroughly.
The fabric softener dispenser works on a siphoning principle.
Make sure that the siphon hole in the dispenser is clear and not restricted or plugged.
You can fill the fabric softener compartment with water and make sure that it is siphoning properly while you are cleaning it.
Make sure that the cover is properly replaced on the fabric softener dispenser when the drawer is replaced in the washer.
You can use the diagnostic test described below to test the fabric softener dispenser.
If the softener dispenser does not fill and dispense properly, you could have a failed dispenser valve, a failed control board or a wiring failure between components.
You indicated that you tested the pump and that it is good. You could have a clogged drain hose or a clogged washer drain that would prevent the washer from draining.
You could also have a failed drain pump even though it runs. If the impeller is jammed or damaged, it will not pump out the water in the washer.
You will likely need to unplug the washer and drain the water out of the tub using a wet/dry shop vacuum.
To check the pump and drain hose at the bottom of the washer, remove the bottom front service panel and remove the drain pump. You may find a clog or restriction in the drain pump or connecting hoses. If the drain pump is damaged or will not work, it will need to be replaced.
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 17, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
LHW0050PQ 2 fabric softener does not enter wsher.
top of the drawer may be blocked where the water enters, also check water pressure
Oct 09, 2009 | Washing Machines
My Whirlpool calypso top loading washer poured water from underneath, water everywhere, what do I do and how do I do it?? No codes showed up. Thanks for any info. Rose
Sounds like the seals & gaskets have failed. If you removed the wash plate trying to unjam the washer and did not also replace the gasket kit, you may have violated the integrity of the water tight seals. However, sometimes also the fabric softener dispenser especially, gets clogged and may overflow and leak if the tubes are clogged with coagulated fabric softener. As I am writing this, my washer's fabric softener dispenser is clogged and the method I use to clear it has not worked this time - a cup of boiling water to melt the congealed fabric softener. One has to open the top lid (method varies by Calypso model - Whirlpool or Kenmore) to get to the dispenser tubing and reservoir underneath to get things flowing again, and in fact I have a small water leak on the floor where the dispenser overflowed a bit. That you have a leak, if it happens to come from such a clog, at least gives you a sign that your dispenser solenoids are not malfunctioning, requiring replacement of one of the circuit boards.
Apr 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Trouble shooting error code
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Fabric softener
Most brands the fabric softener runs out during the filling of the tub.
Jul 27, 2008 | Kenmore Elite 45986 Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytog top load
Fabric softener is mostly a liquid wax. It is common for dispensers to have problems if the you use liquid fabric softener a lot. The softener becomes a sticky solid and can gunk up everything over time. I believe the type of dispenser on your washer simply flushes water into the reservoir at a prescribed time and then dispenses into the wash tub. If this reservoir becomes clogged somewhere it may actually be filling up and overflowing into another reservoir in the dispenser and getting dispensed that way. I would try cleaning the dispenser thoroughly, first. Since it IS dispensing (but at the wring time) I don't think you have a control problem. Try cleaning and let me know if this helps. PS Sorry to ignore your request for online assistance. I was already in the middle of typing a solution for you. I hope this was the help you needed.
Jul 30, 2007 | Maytag LAT3600A Top Load Washer
Washing Machines Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
