Question about The Computers & Internet
When setting up blackberry playbook after entering wrong pin # for 10 timers . it wont let me select a country on the agreement page
  • 134 Answers
SOURCE: I have a blackberry curve 8330 synched to outlook
As annoying as it may be, you might just have to choose the portion that is more important to you - Outlook or the Blackberry. I'm assuming it's the BB.
Since Outlook is different then Outlook Express, you would more than likely have to alter the business contact information in Outlook to make it transfer properly to the BB.
It is a database and not CSV format I'm assuming (comma separated value) format coming from Outlook, but in the process is reads it as a CSV file it seems.
Test it out by entering a dummy business contact and seeing what needs to be where to make it work on the BB.
Since it doesn't have an open source code, I doubt it can be tweaked aside from that.
Posted on Jul 23, 2009
Obertelli
  • 3006 Answers
SOURCE: I have a blackberry 8520 that i have enter the pin
Your phone has suffered a severe software failure and may need professional attention, but you have nothing to lose by trying the following steps (courtesy of GaryCutri on blackberryforumscom.au):-
1. Download the latest firmware from carrier's website - FULL LIST
2. Install the firmware onto a PC running BlackBerry Desktop Manager. DO NOT CONNECT YOUR BLACKBERRY TO THE PC YET!
3. Open Desktop Manager > Select Applications Loader > Select Update Software > Leave the Device PIN\Password prompt on screen.
4. Connect the device and when the PIN appears (or even if it says PIN: UNKNOWN) press OK. If the PIN doesn't appear connect the device with the battery removed and when the PIN appears press OK.
5. Once the device is detected it will show you a list of the firmware to be installed. If this is only a short list select Advanced (or Options on some version) so you can see the full list of software. Ensure you select all the required components.
6. Continue through the wizard and the device will be reloaded within 45 minutes. Please ensure you do not interrupt this process.
7. Once the device is reloaded you will need to resend your BIS service books or if you are on BES (Corporate users only) you will have to reactivate the device (you will need the I.T. department to assist you with this step).
Posted on Oct 01, 2010
  • 9 Answers
SOURCE: Just purchased Blackberry Playbook. Set
Sounds like a bad install on the new operating system. Since your question was posted in April, I'm assuming you have the problem solved by now, or returned the device, but for anyone else looking at this, I suggest either returning the device and exchanging it, or if you prefer to solve it with this device, then leave it on and let the battery run down. Once it is dead, try plugging the device in and powering it on, hopefully that gets you back in business. Blackberry Tech Support is also helpful, their phone number for your country should be on their website.
Posted on Aug 15, 2011
  • 825 Answers
SOURCE: I am having a problem connecting my Blackberry playbook to my wireless internet which uses a speedstream 6300. Any suggestions? Thanks.
Looks like the router is in 'sleep mode', so that it is not able to process any new incoming requests. Restarting the router will make it work in most cases. But there are some cases in which the router needs to be reset and reconfigured for such problems.
Posted on Feb 06, 2012
  • 825 Answers
SOURCE: connect blackberry playbook
This could happen if your router enters into a 'sleep mode'. It continues to provide services for all the connected devices. You can see the network in range(it broadcasts the network name), but you will not be able to make new connections to it.
Restarting the router may solve this problem in most of the cases, but in some cases the router needs to be reset and reconfigured from top to bottom. While doing a reset the router loses its connection with all the connected devices.
In a particular case when you have used the WPS button on the router for connecting the bluray player, then in this case the password will be changed automatically to a random one by the router and bluray-player.In such cases the default password or the password set by you earlier wont work.
you can have a look at the following link also.
http://www.fixya.com/support/r7947146-reset_belkin_router
Try to browse for my other tips under my profile which will help you to explore the problem.
Testimonial: "Thank you."
I have one more attempt at my password and it will wipe out my memory. How do I recover or set a new password?
  1. Use a browser in the BlackBerry PlayBook or a personal or laptop computer and go to the BlackBerry ID Password Reset page.
  2. Enter your username (your BlackBerry ID) in the first box.
  3. Enter the slightly scrambled verification code in the second box. The CAPTCHA system helps prevent computerized attempts at cracking password codes; presumably humans are better at reading those oddly shaped characters. If you have trouble with one set, tap Refresh the Image to get a new group.
  4. Click Submit.
    If you've done it correctly, a confirmation message tells you that reset instructions have been sent to the BlackBerry ID e-mail address. For security reasons, the reset instructions don't go to your BlackBerry smartphone or to your BlackBerry PlayBook. The idea is to prevent an unauthorized user from picking up either device and gaining control of it.
  5. On a personal or laptop computer, log in to the e-mail account you specified and find the message.
    You can log in also on any other e-mail-capable device other than your BlackBerry PlayBook or BlackBerry smartphone. The message comes from bbidpw-donotreply@blackberry.com. If you can't find it, check the spam folder.
  6. Click the link in the message.
    A web browser should load on the device; if it doesn't, tap the link and copy; then open a browser and paste it there.
  7. When the password reset page loads, enter a new password for your BlackBerry ID.
  8. Now confirm.
How to Reset BlackBerry ID Password for Your PlayBook
May 17, 2016 | RIM Blackberry Playbook with 64GB Internal...
My Blackberry Playbook won't allow me past the agreement stage of the initial set-up. There is no country shown in the drop down menu. Advice please
Hey Brian,
This might be a little more complex, but it does work. When you plug your Blackberry into your computer, under the software forget your existing device. From there go ahead and reinstall the desktop software. Unplug your Blackberry and run the desktop manager. In the device menu the only available options are Sync Type, Switch Devices and Exit. Power down the Blackberry. In the desktop software, go ahead and click the Switch Devices button and plug in your Blackberry as prompted. From here be sure you have a local wifi you can connect to and the Blackberry should start up as normal.
Feb 27, 2015 | RIM Blackberry Playbook with 64GB Internal...
Forgot my blackberry id please help
BlackBerry 10 devices
  1. Tap Settings followed by BlackBerry ID
  2. The BlackBerry ID username is displayed
BlackBerry 6, BlackBerry 7.0 or BlackBerry 7.1
  1. From the home screen select Options
  2. Select Device followed by BlackBerry ID
  3. The BlackBerry ID username is displayed
BlackBerry Device Software 4.0 to 5.0
  2. Select Third Party Applications followed by BlackBerry ID
BlackBerry PlayBook OS 2.0
If you are asking me what your Blackberry Messenger password is, I have to smile. If you are in a business and have a Blackberry administrator in IT support, that party can change your password.
Do not panic. Below is an alternative:
However, you can try this Blackberry support page to change your password: http://us.blackberry.com/bbid.html or look at
https://blackberryid.blackberry.com/bbid/recoverpassword/
Feb 27, 2015 | Blackberry Cell Phones
Blackberry password
How to recover a BlackBerry ID using a BlackBerry smartphone
Something important to keep in mind when recovering a BlackBerry ID password is that you will need to use the BlackBerry Browser on your device or a web browser in order to complete the process. This is a result of a security precaution that prevents the password recovery email from being sent to the device. To recover your BlackBerry ID password, use the BlackBerry smartphone browser or a computer to follow these steps:
1. Navigate to the BlackBerry ID password recovery page
2. Enter the email address that you used to register your BlackBerry ID and fill out the CAPTCHA characters
3. A confirmation page will appear stating "A request to reset your password has been submitted"
4. Open the mailbox for your email address on the computer or by logging into the mailbox\webmail using the BlackBerry Browser and click on the BlackBerry ID password reset email (it can be identified by the sender: bbidpw-donotreply@blackberry.com)
Note: Don't forget to check your spam/junk folder in the event that you do not see this email in your inbox.
5. In the body of the email, click the link after the heading "To change your BlackBerry ID password, simply visit"
6. The link will open a new page in your web browser, enter your new BlackBerry ID password in both fields and click Submit
7. You have successfully recovered your BlackBerry ID password!
How to recover a BlackBerry ID using a BlackBerry Playbook tablet
To recover your BlackBerry ID password using a BlackBerry Playbook tablet, follow the steps below. Something to keep in mind is that you may be asked for the answer to the security question that you created during the initial setup of your BlackBerry ID.
1. On your BlackBerry Playbook tablet, open "Options" by taping the gear in the top right corner of the Home Screen
2. From the menu on the left tap "BlackBerry ID"
3. Tap the Pencil icon to the right of "Change Password"
4. Tap "Forgot password?"
5. Enter your password recovery question which you created when the B BID was initially set up and tap "OK"
. Open "Messages" on your BlackBerry Playbook tablet or log into your mailbox/web mail using the BlackBerry Playbook tablet browser and select the email from bbidpw-donotreply@blackberry.com
7. In the body of the email, click the link after the heading "To change your BlackBerry ID password, simply visit"
8. The link will open the web browser on the device, enter the new password in both fields and tap "Submit".
  • That's all there is to it!
Jul 19, 2014 | RIM Blackberry Playbook with 64GB Internal...
My BlackBerry Z10 phone gives bberror/bb10-0015. what must I do?
Standard troubleshooting should always be performed and logs should be submitted for review prior to reloading device software.
Only proceed with reloading the device software to the BlackBerry 10 smartphone or BlackBerry PlayBook tablet if instructed by BlackBerry Technical Support Services or as directed by another BlackBerry Knowledge Base (KB) article.
Warning: The following procedure will delete all data and applications on the BlackBerry device. If possible, back up the data prior to performing the procedure. For information on how to back up data from the BlackBerry 10 smartphone or BlackBerry PlayBook tablet, see KB33526.
Before proceeding, download and install (or update to) the latest version of BlackBerry Link found at www.blackberry.com/blackberrylink.
To reload the BlackBerry 10 OS or BlackBerry PlayBook OS, complete the following steps:
BlackBerry Link version 1.2.3.23 (Windows):
  1. Open BlackBerry Link.
  2. Ensure the computer is connected to the Internet.
  3. Power off the BlackBerry 10 smartphone or BlackBerry PlayBook tablet.
  4. Connect the device to the computer via the USB cable.
  5. Under the Devices heading, click the device name when it is displayed.
  6. Click Preferences at the top-right.
  7. On the left, click Reload Device Software.
  8. Click the Reload button.
  9. Click OK to confirm.
BlackBerry Link version 1.2.1.10 (Mac OS):
  4. Connect the device to the computer.
  5. Click the device name when it is displayed on the left.
  6. Click the Reload button.
    Note: If the device is not detected by BlackBerry Link, at the top of the screen in the menu bar, click BlackBerry Link > Preferences > Reload to complete the reload.
Jan 25, 2014 | RIM BlackBerry Cell Phones
Security wipe
Go online and make a blackberry account and I'd, go to your used email and confirm activation, then go to your device and try again making sure you have an open wifi connection or the password to the one connecting to. If is software issue then turn device off. Hold both power and volume button for up to two minutes until machine shows a sign then release the power continuing to hold the volume or vice versa on all buttons and may be the home button instead of volume if your device is equipped with such. Could be either volume up or down but not both at same time. This should either factory reset device other put in download mode where the ROM software can be flashed to the device or an alternate software can make your device perhaps into an android device. A YouTube search can lead you to more solutions to your problem. Good luck and let us know the out come.
Dec 05, 2013 | RIM BlackBerry PlayBook
How 2 unlock my RIM BlackBerry Playbook?
RIM Blackberry Playbook can be unlocked using unlock code. You can get unlock code for cheap price from unBBlock.com . There you have to give your Country and current network name along with your IMEI number to get the unlock code. They will give you the unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Blackberry Playbook .
Jun 19, 2013 | Computers & Internet
When setting up blackberry playbook for first time. it wont let me select a country on the agreement page
The Playbook attempts to download the license agreement from http://csbeta.websl.eval.blackberry.com/
and it seems this URL is no longer valid, as it returns
"Sorry! Nothing could be found here."
i figured the OS on my playbook is an early release so i'll be forcing an update.
to force an update, i fired up the latest desktop manager, completely turned off the playbook by pressing/holding the power button then clicking turn off, then i plugged it in..
desktop manager then shows an error message and gives you the option to update.. click that and leave it alone for an hour++ (depending on your internet connection)
i started the updated playbook, went through the setup wizard and this time when i selected the country, i got the license agreement and was able to continue.
option 2:
Feb 17, 2012 | Blackberry PlayBook Tablets & eReaders
Just purchased Blackberry Playbook. Set up wifi. Followed instructions on screen & set up account. Accepted agreement. Next screen went to update. Update finished & said it was restarting. ...
Apr 21, 2011 | Blackberry PlayBook Tablet PC
Computers & Internet Logo
24 people viewed this question
Top The Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
thetraveler
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
