Question about Canon Office Equipment & Supplies
How do I replace broken platen glass on Canon MX340 printer
    Habit-Forming:
    New Friend:
  • 81 Answers
Hello Paul,
Unfortunately, if the error still remains, we would have to advise that you contact our support group for additional assistance. Call Now at +1 800 243 0051 ' +1 800 243 0019
Posted on May 16, 2017
What kind of glass is used for copier platens? I can replace a broken one myself if I can get the right kind of glass.
Try ordering the glass from the parts department of the manufacturer. That way you'll know the glass is the correct type and size.
Jul 03, 2014 | Canon imageRUNNER 1023iF Black and White...
My conon printer mx340 says ducuments in adf error
Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Jun 27, 2011 | Canon MX340 AllInOne InkJet Printer
Where is the platen located
The platen is the part that covers the large original glass. That is why this glass is sometimes called the "platen glass". More commonly the glass is called the original glass because that is where you lay the original to be copied if you are not using the feeder.
Thank You for using Fixya.
Jan 10, 2011 | Canon imageCLASS D760 All-In-One Laser...
CANON IR1022A PLATEN GLASS
Once you clean the glass, you must power down the unit completely. They error won't reset automatically.
Mar 05, 2010 | Canon Office Equipment & Supplies
Keeps stating remove paper from platen glass before copying when trying to use the feeder. Nothing on the platen glass.
First you must lift the dadf all way up, because (from front looking) on left side under /by dadf hinge is white flap.This flap registers the lifting and pulling down of dadf.Probably is only that.
...but check if its broken or stuck,...
Or you have broken sensor or some part in sensors, or piece of paper, or similar in dadf
Feb 18, 2010 | Canon ImageRunner 2020i Copier
How do i clean underside of platen glass Canon MP160
for mp160, flip the cover open, the one that you open to gain access to the ink cartridge. you will see two screws at the underside of the scanner base. unscrew both. gently pull down at the front control panel and pop up the front lip of the plastic that holds the platen glass. then, at the back of the printer, adjacent to the paper loading tray, just below the platen glass cover, you will see two clip like stuff. remove the tray by pulling it upwards vigorously but firmly. then, get a flat screw driver to pry these up to release the lock. then, facing the printer, gently pull the whole of the platen glass, together with its plastic frame, towards you. do this while gently rocking the platen glass up and down, or left and right. to return the platen glass, reverse the process.
Jan 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Canon problem
the problem may the platen glass!!!!!!!!!!!
is the platen glass ok, did you change it? is the white on the platen ok? it uses it for reference.
Aug 19, 2008 | Canon Office Equipment & Supplies
41 people viewed this question
old marine
old marine
