Question about Hilti Drills
Hilti 18v impact driver , was working in rain and impact just stop , now does nothing
VtToolMan
  • 704 Answers
SOURCE: My rattle gun 18V LXT Impact Driver BTD141 has a
There are a couple of ways to try to free the bit from the drill chuck. But slow and steady is the key, don't hit anything too hard, so as to not damage the chuck in the process, nor break off the bit in the chuck.
You'll need to put the bit into a bench vise and reverse the drill slowly and carefully. Make sure the bit is tightly secured in the vise and that the drill won't spin your hand around and slam it into the bench when you pull the trigger.
As a last resort, you can try tapping the bit sideways, to get it loose. With chuck opened up all the way possible, gently tap the bit sideways. This should also free the bit, but be very careful not to snap the bit off in the chuck, or you'll have a worse situation trying to get a broken bit out of the chuck.
If none of these work, you can attempt to secure the stuck bit in the bench vise and try to tap the drill chuck using a hammer and a flat brass bar resting against the drill chuck, so you don't damage the chuck. Just tap the brass bar to drive the chuck free of the stuck bit. You have to watch the bit in the vise to make certain it's not slipping and that the chuck is getting free.
Hope you find this Very Helful and best regards!
Posted on Sep 22, 2009
Mike258
  • 1498 Answers
SOURCE: Hitachi Cordless Impact Driver gearing problem
The speed shift slider switch wasn't lined up correctly when the unit was reassembled.
Unfortunately, you going to need to repeat the disassemble/reassemble process once more.
I've been there. It doesn't take much to be out of alignment. Set everything to the lowest setting (clutch, speed) and take your time.
Best regards
Mike
Posted on Apr 22, 2010
  • 34 Answers
SOURCE: my makita 18v li-lon impact driver has only 70%
Worn brushes or wrong trigger.
Posted on Oct 20, 2010
  • 147 Answers
SOURCE: i,ve got a hilti hammer drill te 60 and a hilti si
Most likely, here is a link to find a hilti shop near you.
http://app.xtremelocator.com/custom/hilti/SearchForm.php
Posted on May 07, 2011
rowdy45176
  • 2176 Answers
SOURCE: where i can buy power switch for hilti SID 144-a cordless impact driver
call HILTI direct at 1-800-879-8000 and they can either give you the location of a local service center or buy from them direct. They have excellent customer service people.
Posted on Feb 08, 2012
Can C7-24 hilti charger that had been out in the rain be repaired
try putting it in a bucket covered with rice for a couple days...sometimes this will absorb any and all moisture in the device
Jun 16, 2016 | Hilti Drills
Stopped working
battery or electric and what make?
Nov 29, 2015 | Drills
My impact driver when in reverse works fine but when in forward it will work for a few seconds then stop and keeps doing that. why?
I'd be looking for a defective forward/reverse switch, or a bad connection/wire on the forward side between the switch and the motor.
Jul 01, 2015 | Dewalt DW056 18V Heavy Duty 18V Cordless...
Ryobi 18v variable speed impact driver. I need to know something about speeds and settings. Bob
Just keep it on high, vari-speed on an impact driver is not very useful unless working with delicate materials.
Mar 23, 2010 | Ryobi 18v Variable Speed Impact Driver...
I NEED TO REPLACE CHUCK ON DRILL CB118026...LOOKING DOWN THE CHUCK OPENING, THERE IS A SQUARE, NOT A ALLEN KEY HEAD, HOW CAN I TAKE CHUCK OFF, THANKS
What make is that model of drill?
I have a hilti that uses a square bit that is about 4mm and it came with it. can a Robertson screwdriver fit in it?
Mar 05, 2010 | Ryobi 18v Variable Speed Impact Driver...
How do i take off the chuck from my dewalt 18v xrp so i can use my hilti smd57 mag (drywall cont.' screw magazine) i unscrewed the screw down the shaft but now im stuck????
go to the tip section or under my profile in the section and there are detailed instructions on how to do this. Let me know if you still need more help.
Dec 20, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Drills Logo
69 people viewed this question
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
