Question about Dryers
How do i get the cage around the fan open or off,bionaire transformable stand fan,bsf1411ar-cn
2 Suggested Answers
  • 25 Answers
SOURCE: Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
Posted on Apr 16, 2009
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
How do you disassemble a delonghi portable air conditioner to replace the plastic fan squirrel cage?
See if there is a youtube video available or go to delonghi's web site to get a diagram
Apr 09, 2015 | DeLonghi Heating & Cooling
How to change remote control battery for a Bonaire heater
The remote for Bionaire® 20" Ceramic Mini-Tower Heater with LCD Control uses BUTTON cells (Disc type, 3 volt, CR2025)..
Open the remote as shown in page 4
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/-/Sites-bionaire-ca-Library/default/dw869fb9a8/documents/instruction-manuals/BCH9208-CN_EN.pdf
Jan 12, 2014 | Bionaire BT200RCU Tower Fan
Heater bionaire bch9224-cn no heat
The Bionaire BCH9224-CN is a ceramic space heater, one of apparently 4 related units. The 9224 is the tallest in the family and I also have the shorter BCH9212-CN. They are electric so I have no idea what all this talk about 'gas', 'pilot light' and 'flame' is. My 9224 failed in a way that seems quite common with Bionaire space heaters in general, namely, first the smell of burning electrical insulation, then a snap or pop accompanied by a flash of light out the lower side, and then no more heat. It is possible that the original questioner had this happen but wasn't around to witness it. Now it is possible that the failure is in the electrical control board but in my case (and in fact I'm betting for many or most of the Bionaire failures) it was a wire running to the ceramic heating block (element) that fried at the connection to the ceramic element. I would say it is very unlikely the failures of the Bionaires are in the ceramic heater blocks themselves, and in fact the 9224 and the 9212 (and I assume many or most of the other Bionaires) actually have two ceramic blocks/elements fastened together, one being used for the 750 watt heating and both for the 1500 watt heating. The central wire running to the blocks must support enough current (about 12.5 amps) for both of the blocks, whereas the wires to the individual blocks need half that (about 6.25 amps). In my 9224 unit the weak spot was clearly where the central, common wire was connected to the spade-like connector that was crimped onto the central, common tab of the ceramic block pair. At first I thought I'd just toss the thing but then I opened it up, did the autopsy and repaired it by replacing the 3 wires from the circuit board to the ceramic blocks with 14 gauge wire, and made the connection of the wires to the three soft metal (tin or tin alloy?) tabs of the ceramic blocks by carefully drilling holes in the tabs and bolting eye, crimp-type wire connectors to the tabs using small screws. Oddly enough I opened up the smaller unit (the BCH9212-CN) and it has the same ceramic element pair but no indication of burnt wires.
Jan 08, 2012 | Bionaire Heating & Cooling
Apr 16, 2009 | Bionaire BSF1731RC Stand (Pedestal) Fan
Has a burning smell
That depends on what's burning! Unplug it and search online for the manual for that thing, or call Bionaire's help line once you look that up.
If you can safely do it, and are unworried about warrantee conditions, open it out and find out what was burning and what caused it to burn; for example, note the scorchy motor and/or control components and remove the cat toy out of the fan blade. At this point you get to observe and perhaps test whether the motor (or transformer, etc.) was burnt to ruin or can still run with care and reassembly.
Aug 16, 2008 | Bionaire BT210RT Tower Fan
Remote Control Doesn't Work
You could pick up an IR tester. Your local electronics hobby store should have them. Also, you sound as if you have some electronics ability, you could do a search on the net and find a electronics hobby site and build yourself a tester. This is what I did. Now, in my 27 years of electronics I have never seen a bad IR section of a remote. the most common problem is broken solder connections. remotes get dropped, tossed, stepped on, etc... Open the unit up and look for bad solder connections. They do not have to have a physical break to be bad! If they are grey instead of shiny or if you see a ring around the lead then the connection is bad. Reflow all connections and clean all contacts. I would think that will get it back to a working conditon.
Sep 21, 2007 | Bionaire BSF1731RC Stand (Pedestal) Fan
How to set the temperature
Look up this fan on amazon.com. In the comments/reviews a gentleman posted instructions for fixing the thermostat (it involves opening up the fan and repositioning the thermostat wire).
Jun 19, 2007 | Bionaire BW2300 Window Mount Fan
Dryers Logo
Top Dryers Experts
