When tring to start dish washer 3000psi I only get a lock symbol
Honda11hp 3000psi 4gpm started pulsing
Valves are stuck, may need to replace them.
Oct 24, 2012 | Garden
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 | Garden
My Bosch Classic 6 is dispalying the key symble and will not let me proceed with the washing cycle thank you
When the machine is on, and the key symbol is showing, push and hold the start button for 5 full seconds to turn the child lock off. Holding the start button also turns the child lock on if it is not already on (it is a toggle switch).
Feb 28, 2011 | Washing Machines
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
What type of oil is best for the 3000psi Honda power washer?
a 30 weight nondetergent oil is recommended, available at any auto parts store.
Aug 05, 2009 | Honda Pressure Washer PSI 3000
My child safety lock is on my dish washer how do I get it off
For my old GE washer, there was a button with a lock icon. To lock/unlock it, you had to hold that button down for 10 seconds.
Hope this helps!
Aug 03, 2009 | KitchenAid KBLC36FKS Bottom Freezer...
Kitchenaid dishwasher woudl not work MOD KUDPO1FLWH6
is it on steady??? or blinking??? if on steady try pressing nad holding the button with the "lock" symbol on/or above it, thinknits the heat button, for 3 secs it will "unlock" the controls, if blinkin then its a diff issue, may be a bad door switch not recognizing hte door being closed therefore wont start,
Dec 02, 2008 | Dishwashers
The dish washer won't start
press the key with the lock button for 5 seconds. the lock indicator light should then disappear.
Jun 09, 2008 | Kenmore Dishwashers
Washing Machines Logo
Top Washing Machines Experts
