Question about Dishwashers
Dish washer is locked from starting. It's a 3000psi
Will not pump above 3000psi?
probably has a relief valve in the pump head that prevents over pressure from damaging the pump
3000 psi is extreme for a pressure washer and will remove paint from a vehicle , blow out gaskets on engines , remove cement surface , peel timber surfaces
Sep 08, 2015 | Comet TW 5050 S - Pressure Washer...
Honda11hp 3000psi 4gpm started pulsing
Valves are stuck, may need to replace them.
Oct 24, 2012 | Garden
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 | Garden
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
What type of oil is best for the 3000psi Honda power washer?
a 30 weight nondetergent oil is recommended, available at any auto parts store.
Aug 05, 2009 | Honda Pressure Washer PSI 3000
My child safety lock is on my dish washer how do I get it off
For my old GE washer, there was a button with a lock icon. To lock/unlock it, you had to hold that button down for 10 seconds.
Hope this helps!
Aug 03, 2009 | KitchenAid KBLC36FKS Bottom Freezer...
The dish washer won't start
press the key with the lock button for 5 seconds. the lock indicator light should then disappear.
Jun 09, 2008 | Kenmore Dishwashers
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
