Question about Dryers
How do you clean fan blades - Dryers
Blades moving but cant feel no air
if it is a newly installed overhead fan check the fan direction switch just above the motor
Jun 30, 2016 | Dryers
Noisy when running
condenser fan blades are cover with lint or the fan motor may be going out. Clean fan blade first before doing anything else. If noise stops after cleaning the fan blades; hooray! If not you might have to replace the fan motor itself. Test and re-check before taking other step(s)
Jan 04, 2011 | Haier BC112G Wine Cooler
How do I fix my fan from shaking so badly?
Did you just clean the fan? If while cleaning, you bent a fan blade, even a hair it will shake. Blades are perfectly balanced. Moving one just a hair, will cause the fan to shake. Trying to re=balance the blade(s) is futile, you can get it close, but it will take somr patience. If the fan has built up dust on the blade(s) will begin to shake if some blew off unevenly
Oct 07, 2010 | Lasko High Velocity Space-Saving Blower...
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Cleaning black wood fan blades for casablanca fan
I have had good results using a product called Scott's
Liquid Gold. It's available in many stores including grocery stores. I started using it to clean up console televisions after repairing them. Make sure you wipe it clean after using it. The residue will attract dust if you don't. It's sort of a "super Pledge"
Jun 25, 2010 | Casablanca Fan 6632T Panama® II Weathered...
Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Jul 03, 2009 | Vornado Circulating Fan
Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
Apr 16, 2009 | Bionaire BSF1731RC Stand (Pedestal) Fan
Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
Jan 04, 2009 | Honeywell HV-180 Floor / Box Fan
This would seem to be the motor heating up and cutting out on a thermal overload. Check to see if the motor area is clean and that the fan blades are clean. To clean the motor you can blow compressed air through it. To clean the blades disassemble the cover remove the blade and clean with a mild soapy solution.
May 28, 2008 | Patton Electric Dryers
Dryers Logo
21 people viewed this question
Top Dryers Experts
