Question about Panasonic Microwave Ovens
Is there a fuse on my panasonic nn-s255 if so where is it located thank you
    Top Expert:
  • Panasonic Master
  • 45,144 Answers
The fuse is located inside the unit.
Posted on May 16, 2017
NN-T563 shuts off after 5 seconds
We recommend you use the below link to locate an authorized service center. Panasonic microwaves have a 5 year warranty on the microwave.
www.panasonic.com/repair
Apr 12, 2014 | Panasonic NN-S563 Microwave Oven
No power on microwave panasonic NN-S255
It all depends on your full model number (you left off the suffix) but one version's service manual is here.
In some cases, it is a fuse or thermostat / thermal cutout / TCO, in others a surge has occurred, requiring circuit board repair.
This surge can be from the power line, or due to blown cooktop bulbs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order Panasonic parts at
Encompass here.
Dec 04, 2011 | Panasonic Microwave Ovens
Everythink works except the microwave will not start. Is there a fuze that can be replaced to fix this ? Model # NN-2551 I found the user manual on-line, but I can't find the product spec sheet breakdown...
I'm not sure what you mean by "everything works". do you mean that all the lights and the timer work. Could it be in the timer or clock mode? Try pushing the timerand cancel buttons together.
Try changing the time using the clock function.
I believe your model has a child lockout. Please check your manual for instructions on unlocking this function.
Is it hardwired or plugged in? If it is plugged in you can try a power reset, by unplugging it, waiting a few minutes and plugging it back in. It is completely unsafe to try to work on a hardwired Microwave.
Please let us know if this solution is helpful to you. Thank you.
Dec 20, 2010 | Panasonic NN-S255 Microwave Oven
Main fuse blows when I press start on panasonic nn-255 microwave opened up microwave and see 25 ohms on cn702 of invertor circuit board, what's normal? This would appear to be a short to the 120v supply,...
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Apr 17, 2010 | Panasonic NN-S255 Microwave Oven
My panasonic over the range microwave model NN-S255 suddenly went dead, power cord is fine, is there a fuse that could be replaced in the microwave somewhere?
I have same problem. Disconnect the power. Take the 3 screws out of the top of vented front thus exposing 2 screws that hold down the touch pad .remove them and move touch pad out of the front and out of the way. on the extreme top right within the compartment there is a circuit board that has a fuse on it. replace the fuse and try to restart the microwave. if the fuse blows again you have a major problem probably the magnetron. If you need further help call me (403)870 9110.........Ron
Feb 08, 2010 | Panasonic Microwave Ovens
Panasonic NN-P794SFR microwave unit that spins not rotating
there is a switch to turn it on or off. the turntable is replaceable
Feb 07, 2010 | Panasonic NN-P794SF Microwave Oven
Was cooking and it made an electrical short circuit sound and died. About 1.5 years old. Can it be fixed? Nothing happens when the power button is pushed. It is on its own breaker and the breaker did not...
Hello. Yes it can be fixed. The issue though is the cost of the repair vs the cost of replacement. Call a repair shop and get a firm quote on the repair and also check the price of a new microwave. then you will know how to proceed. Regards, Joe
PS please rate my answer. thank you and happy holidays
Dec 21, 2009 | Panasonic NN-S255 Microwave Oven
Panasonic nn-s255 wont turn on
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more help.
William E. Miller
prototech@usa.net
Sep 08, 2009 | Panasonic NN-P295SF Microwave Oven
Microwave
It's usually located on the floor of the oven behind the control panel, or with the door switches. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk Feel free to contact me directly if you have further questions. I appreciate your thoughtful rating of my reply.
Jun 17, 2007 | Panasonic NN-S960WA Microwave Oven
Microwave Ovens Logo
133 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
