Question about Craftsman Garden
Instructions on how to hook up linkage for carburetor and choke assy on a Craftsman Riding Lawn Mower Model 917.276030. Need pictures if possible
    Top Expert:
  • Craftsman Master
  • 43,113 Answers
Check YouTube for something similar.
Posted on May 16, 2017
I have a problem with the linkage on my model #917.377190 lawn mower.
Hook the wire that goes to the governor to the butterfly on the carby , the other should go to the choke.
Nov 11, 2014 | Craftsman Garden
Why is my Craftsman lawn tractor so hard to start?
Most likely needs valves adjusted. If you can give model number off of the engine, i can try to find the manual or instructions on how to do this for you.
Jun 28, 2014 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman riding mower dies after it gets warmed up
Check the choke. Typically these are automatic types on most new mowers. The choke is closed during cold starts then automatically open as the engine warms (think of it like a car that fast-idles in the winter, then slows down as it warms...it's not exactly the same thing, but in theory works on the same principle).
What could be happening with your problem is that the choke is stuck closed or partially closed, and remains closed after the engine warms. When the choke is closed when the engine is warm, it floods the engine with fuel and stalls (and can be difficult to restart, if you can get it to restart).
To test if this is your issue, operate it until it's warm and quits. Remove the air filter and check that the butterfly valve at the top of the carburetor is open. If it's closed, open it all the way (might have to put a screwdriver, or something in there to hold it open), then try to restart it. If it's open all the way, there is likely a fuel flow restriction to the carb, or in the carb, but these problems typically cause problems running the engine hot or cold.
Two recommendations.
1. Remove carburetor, and clean with spray carb cleaner. The choke is the butterfly valve visible where the air filter attaches. Check the linkage for debris, bent or restricted linkage. After cleaning and re installation, check for free movement of butterfly choke valve.
2. Prevention. There is not a lot that can be done, but to clean the carb/choke and throttle linkage during spring tune up before first use. May require more cleaning depending on amount of use. ALWAYS USE 100% GAS, NO ETHANOL. If you must use ethanol because 100% gas in unavailable, always mix with an additive that neutralizes the effect of the ethanol. Infrequently used engines (unlike cars) that use ethanol are prone to problems because the fuel system retains water. Carburetors do not like water, cause corrosion, and repairs can be costly. For example, Someone just gave me a nice (fairly new) Bolens Riding Mower (38" B&S engine - worth about $800 ) that would not run, they just got tired of it not running right and the cost of repair shop work was about $200. I bought a $65 carb on Amazon and now I've got a nice new riding mower. They saved $.50/gal on gas and I saved $740 on a new mower...yeah, baby!
Sep 02, 2013 | Craftsman Garden
22 horse kawasaki riding lawn mower will not run at full throttle unless the choke is engaged
That is not a good situation. Too rich of a fuel adjustment can wash the bores out on that engine and prematurely wear it out! You will likely need to have the carburetor linkage and plate adjusted so that full throttle operates without engaging the choke. (If this is a single lever that you slide from slow, idle speed to fast, then on to choke)
May 09, 2010 | Husqvarna Garden
I need to charge the battery
check under the seat and possibly under another plastic cover
May 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Throttle doesn't work properly
try sears.com go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
May 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Apr 19, 2009 | Craftsman Garden
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
