Question about Garden
HC-1500 hedge trimmer runs at high speed,but not at low
HC-1500 hedge trimmer runs at high speed,but stalls at low speed. Also will not idle
    Scholar:
  • 173 Answers
The first thing to do, is to clean the air filter, and remove the plug, and clean with a wire brush, if neccesary.
You should also bear in mind, that the timing may well, be in need of retarding, ever so slightly.
If problem still persists, you known where we are.
Posted on Jul 25, 2009
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
My toro weed trimmer starts good runs great for a few minutes then starts to bogg out then dies, will start back up but won't stay running.i already replaced the fuel tank, lines and filter.
Check the air filter isn't dirty.
If the machine runs ok on high speed but cuts out while idling, the idle speed may be too low. There is usually an adustment screw for increasing the speed.
If the fuel line is a flexible type which moves around inside the tank, check it is able to move freely because if you are cutting at awkward angles, the end of the line can end end up above the surface of the fuel, **** in air and airlock the line. You can eliminate this as the problem by fully filling the tank.
Check whether there is a one way check valve on the tank. This vents air into the tank as the fuel leaves for the carburettor. Sometimes particles of dirt can get stuck in this.
Apr 30, 2011 | RTO Weed Eater Hedge Trimmer 20cc,...
The poulan hedge trimmer engine will run for a few seconds and than cut off.
If the fuel line is a flexible type which moves around inside the tank, check it is able to move freely because if you are cutting at awkward angles, the end of the line can end up above the surface of the fuel, **** in air and airlock the line. You can eliminate this as the problem by fully filling the tank.
Apr 28, 2011 | Poulan WeedEater Hedge Trimmer 25cc Engine
The trimmer starts but will not keep running, I replaced fuel lines and filters and put a rebuild kit in the carb. Same problem, starts fine but will not keep running
Its a longshot but I had a problem with my hedge trimmer, it kept cutting out when idling.
It turned out that a clutch spring was broken so the clutch shoes had nothing to restrain them and would fly out and make contact with the clutch drum and stall the machine.
Air locks in the fuel lines will also cause this symptom. These can be caused by running the machine with low fuel level in the tank and cutting upside down or at a sharp angle.
Mar 01, 2011 | Echo Gas 20 In Bar Double Reciprocating...
Does anyone know the factory mixture setting screws for electrolux hedge trimmer
Carefully Bottom each screw and turn out 1 to 1 1/2 turns. This should get you started. Adjust low and high speed screws till it idles and does not hesitate on high
Oct 21, 2009 | Electrolux Gas Hedge Trimmer
Looking for owners Manual for Echo HC 1500 Hedge Trimmer.
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
Apr 02, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Garden Logo
155 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
