Question about Panasonic Televison & Video
Is there a fuse on my panasonic nns255 if so where is it located thank you
Panasonic Microwave Oven unexplainedly without power. Model No. NNS954WF. Serial # 6A34160395.
If you remove the microwave case, follow the power cord inside the microwave to the fuse. Panasonics will usually have a 15 or 20 amp ceramic fuse available online or at a local appliance repair shop. Of course remove power from the MW and don't touch any wiring or terminals except the fuse wiring.
Nov 14, 2017 | Microwave Ovens
I have a Panasonic MW Oven (NNS255) I Cannot open the door. How do I get access to behind the control panel to fix whatever is broken
you need to take the housing off the microwave to get to the door latch..once you get it open you should be able to find access screws to take the door apart to see whats broken.please rate me thanks
Aug 10, 2008 | Panasonic Microwave Ovens
Cook top light will not turn off on Panasonic Microwave nns255
Check your manual and see if you purchased the correct type of replacement bulb (wattage).
Apr 25, 2009 | Panasonic NN-P295SF Microwave Oven
Where is the fuse and reset button for the Panasonic NE1064TC located. Can anyone help with this. Thanks,
On our Panasonic microwave there are two fuses, a regular cylindrical current fuse and a one-time "thermal fuse." If you remove the case which in our unit is held on by a handful of screws on the back of the unit, both fuses are visible if you stand at the rear of the unit and look on the left hand side. The thermal fuse is the gadget attached to the top of the magnetron heat sink. It is typically in the white wire. The current fuse is located in the black wire. I hope this helps!
Mar 27, 2009 | Panasonic NE-1054 1000 Watts Microwave...
Panasonic SDR H20 camcorder
Hi There, You probably have a blown out fuse. Unless your a service tech with a service manual, it may be hard for you to locate where the fuses are. A panasonic service depot could give you a proper estimate.
Thanks, mr cicmo
Jan 04, 2009 | Panasonic Video Cameras
Fuse location
Good day JC, these fuses are surface mount fuses so they can not be changed by anyone. If you do change the fuse and there is a fault on the pcb you could make things worse. So i recommend that you take it to a Panasonic dealer or technician who has electronic experience in camera repairs.
May 11, 2008 | Panasonic PV-GS39 Mini DV Digital...
Won't turn on
Follow AC cord in to clip-in glass fuse....replace with SLOW
BLOW 6.3 amp ( T-type) Panasonic factory correction...T.
Dec 19, 2007 | Panasonic CT-32SX31 32" TV
AG 460 panasonic camcorder" FUSE LOCATION"
just follow the battery and you will see the small fuse color white and have a mark of 3.15 at the bottom of the battery socket..
Aug 10, 2007 | Panasonic AG-455 Camcorder
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
