Question about HP Office Equipment & Supplies
HP laserjet 1020 input tray does not close and i don't feel any click when trying to close it
Benimur
  • 6966 Answers
SOURCE: HP laserjet 1020 driver
You can download the appropriate driver for an HP 1020 here. Pls be reminded that drivers are OS specific.
Good luck and kind regards.
Posted on Dec 09, 2007
pagebor
  • 2785 Answers
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=laserjet+1020&submit.x=8&submit.y=8
plz paste the above web address in your browser and download the drivers
thanks for posting
raj
Posted on Jun 13, 2008
  • 9 Answers
SOURCE: Paper Jam HP LaserJet 1020
Papper never realy "jams" the problene is usualy that the paper is late reaching the next paper sensor. What i would sugest is that you clean the paper pickup roller it is usualy in the shape of a D. Clean it with dishwassing soap dont use water just clean soap rub it on with a clean cloth until the roller is dry so use a small amount. This should solve your prbleme.
Posted on Jul 04, 2008
SOURCE: HP 1020 Error Message
Had the same problem. Changed cartridge. Still didn't work. I suggest taking out cartridge and examining inside of printer carefully. I found a piece of balloon and a hair tie (aargh!, my kids). Works now.
Just wanted to post this as one more thing to check before junking the printer or spending money on HP support.
Posted on Jul 29, 2009
Chittaranjan
  • 62 Answers
SOURCE: Error message coming up: The HP LaserJet 1020 has
send your printer for service. seems like, one or two sensors are malfunctioning.
Posted on Aug 09, 2009
The HP laserjet 1020 paper tray is not closing
too much paper in tray remove some until door closes
May 16, 2017 | HP Office Equipment & Supplies
HP LaserJet 1020 Printer, automatically pick-up paper as soon as it turn-on.
Hi.
I guess there is to much paper in the input-tray. Try lowering the paper-level in the tray and if it will act better..
Feb 18, 2014 | Office Equipment & Supplies
Tray setting of HP laserjet 1020 printer
This can be done i several ways.
If your printer is a network-model, you can enter the printers IP-address into your favorite web-browser and set the settings as you want from the web-interface.If your printer is a USB-model, you have to download the software for the LaserJet 1020. This package contains a software called Toolbox, and that's the software you need to set proper settings in your tray. Follow the link for downloading the Toolbox-package.
http://ftp.hp.com/pub/softlib/software8/COL14041/lj-39322-2/hp_LJ_1020-1022_Full_Solution.exe
Apr 20, 2012 | HP LaserJet 1020 Printer
LOCATION OF PRINTER SENSOR
Jams
Clearing jams
CAUTION Do not use sharp objects, such as tweezers or needle nose pliers, to remove jams.
Damage caused by sharp objects will not be covered by the warranty.
CAUTION Always pull jammed media in the direction it would travel through the paper path.
Do not pull jammed media against the direction of travel through the paper path to avoid damage
to the printer.
To prevent damage to the printer when clearing jams, including jams in the output bin, always open the
print-cartridge door and remove the print cartridge. Keep the door open and the cartridge out until the
jam has been cleared. Opening the print-cartridge door and removing the print cartridge relieves tension
on the printer rollers, which prevents damage to the printer and makes the removal of jammed pages
easier.
Occasionally, media becomes jammed during a print job. You are notified of a media jam by an error
from the software and the printer control panel lights. See Control-panel lights (HP LaserJet 1010 series
printers) on page 102 or Control-panel lights (HP LaserJet 1020 printer) on page 106.
The following are some of the causes of media jams:
The input trays are loaded improperly or are too full. See Loading media on page 25.
NOTE When you add new media, always remove all of the media from the input tray and
straighten the stack of new media. This helps prevent multiple sheets of media from feeding
through the printer at one time, reducing media jams.
The media does not meet HP specifications. See Media specifications on page 21.
Typical media jam locations
Print cartridge area: See Removing a jammed page on page 43.
Input tray area: If the page is still sticking out of the input tray, gently try to remove it from the input
tray without tearing the page. If you feel resistance, see Removing a jammed page on page 43.
Output path: If the page is sticking out of the output bin, see Removing a jammed page
NOTE There might be loose toner in the printer after a media jam. This toner clears up after
a few sheets are printed.
Use the procedures in this section to remove a jam.
CAUTION Media jams might result in loose toner on the page. If you get any toner on your
clothes, wash them in cold water. Hot water will permanently set the toner into the fabric.
Partshere Troubleshooting
CAUTION To prevent damage to the printer when clearing jams, including jams in the output
bin, always open the print cartridge door and remove the print cartridge.
To prevent damage to the print cartridge, minimize its exposure to direct light. Cover the print
cartridge with a sheet of paper.
NOTE The following illustrations show the HP LaserJet 1020 printer. The same procedure is
used to remove a jam in the HP LaserJet 1010 series printers.
Open the print cartridge door, and remove the print cartridge.
Grasp the middle edge of the side of the media that is most visible, and carefully pull it free from
the printer.
jams. Damage caused by sharp objects will not be covered by the warranty.
Do not forcefully pull jammed media against the direction of travel through the paper path to
avoid damage to the printer.
When you have removed the jammed media, replace the print cartridge, and close the print cartridge
door.
After clearing a media jam, you might need to turn the printer off then on again.
NOTE When you add new media, remove all of the media from the input tray and straighten
Sep 25, 2011 | HP LaserJet 1020 Printer
Uninstall drivers hp laserjet 1020 impossible. setup says it has to interrupt.
If the drivers can't be uninstalled don't worry, the most likely cause is that the drivers have become part of the windows driver database. Leaving the drivers on your computer will do no harm.
However you may try to uninstall the drivers by navigating to the Windows control panel and then double clicking Add/remove programs. Find the printer driver in the list and click remove.
Take care!
damnor01
May 25, 2011 | HP LaserJet 1020 Printer
Problem for HP LaserJet 1020 Printer HP laserjet 1020 driver
Click Here for your hp 1020 driver that you'll need... Hope this helps and if so please mark FixYa!!
Aug 23, 2010 | HP LaserJet 1020 Printer
Every time i try to print multiply pages a window opens up
select the proper tray from the propeties of printer. it will take paper from that tray.
Nov 26, 2008 | HP LaserJet 1020 Printer
HP Laserjet 1020 reprints on logon
Turn off printer, Goto Control panel then printers and faxs, double click on your printers icon, a box opens with your pending prints, select file and cancel all documents, close all windows, restart printer
Dec 16, 2007 | HP LaserJet 1020 Printer
Regarding printing of envelopes.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00602236&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=439428&productBigSeriesOid=14924&spid=439320&pname=HP+LaserJet+1020+Printer&opname=HP+LaserJet+1020+Printer&pname_desc=HP+LaserJet+1020+Printer&st=1&ptype=consumer&stype=pn&qry=printer+doesnt+print+the+first+time&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+1020+Printer&cqry=&uqry=
Oct 20, 2007 | HP LaserJet 1020 Printer
26 people viewed this question
Seeker5211
Seeker5211
