Question about Dymo Office Equipment & Supplies
My Dymo RhinoPro Labeler 1000 is wasting label tape by printing excess. I have it on the smallest lettering.
  • 19 Answers
SOURCE: won't print
Here is the Dymo site for this issue:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_alp.php?p_li=&p_accessibility=0&p_page=1&p_cv=&p_pv=2.22&p_prods=21%2C22&p_cats=&p_hidden_prods=&prod_lvl1=21&prod_lvl2=22&p_search_text=&p_new_search=1&p_search_type=answers.search_nl
Type "light print" into the search box and the first result is the link you are looking for.
Here is the text of the link:
Poor Print Quality from Electronic Labelmaker trnsp.gif Question I have an electronic labelmaker that is printing poorly. The print on the label is either very light, incomplete, or striped. How can I resolve this?
trnsp.gif Answer Proceed with the solutions listed below if you have an electronic labelmaker. If you have a LabelWriter printer that is printing poorly, click here.
Solution 1:
Replace the existing batteries with a new/fresh set of alkaline batteries. The print head requires a significant amount of battery power to ensure proper printing on the label. Light print on the label may be an indication that the batteries need to be replaced.
Solution 2:
Replace the existing tape cassette with a new tape cassette. Light printing may be an indication of bad label stock.
Solution 3:
Using the special brush supplied with your labelmaker (located on the inside cover of the cassette compartment) or a cotton swab with a soft solvent (e.g. rubbing alcohol), carefully clean the transporter roller and print head. Dust, dirt, or glue may accumulate on the rubber transport roller or print head inside the cassette compartment and adversely affect print quality.
If the solutions listed above do not resolve the problem, please contact DYMO Technical Support to obtain a Return Material Authorization (RMA) Number.
Obtaining a Return Material Authorization (RMA) Number:
  1. Click the Ask a Question tab at the top of this FAQ.
  2. Fill out the email form completely and include the following information in the Problem Description field:
  • Full Name
  • Full Shipping Address (No PO boxes)
  • Phone Number
  • Date of Purchase
  • Model Name/Number
-hope this helps.
Posted on May 19, 2008
SOURCE: ptouch 1100QL waste of tape issue
It isn't actually "before the actual letter comes out," as you said, but rather after. You have probably noticed that you must do a "feed" first or the cut won't clear the end of the label and you have to do it again. This just reflects the distance between the print head and the cutting bar.
There's no way to avoid this if you must have the one label you just printed right away and you don't have any more labels to make at the moment.
However, if you have several labels to make, you can economize by printing them one right after the other (without any "feeds" or cuts), then once you're all done, do a "feed" and cut. The labels will be close together, with little waste except at the ends, and you can cut them apart with a scissors.
Posted on May 26, 2009
MCSE_Fixit
  • 23 Answers
SOURCE: how do you print vertical labels?
Here is the link to your users manual, which will help explain other functions you may find useful.
http://global.dymo.com/enGB/Manuals/LetraTAG_QX50.html
Hope this helps...
Gods Bless.......
Posted on Jun 22, 2009
SOURCE: Problem feeding 9m tape in Dymo 1895
I have one of these and there is a white sliding button on one of the broad sides of the labelmaker. It slides from 3/8 inch to 1/4 inch. It is located toward the top right. It's NOT the side with the letter wheel but the opposite side. If yours doesn't have t his button, it probably won't take two sizes of tape. (But I'd be surprised if it didn't have the button.) Hope you find it.
Posted on Sep 01, 2010
  • 3 Answers
SOURCE: My Dymo Labelwriter 450 turbo feeds out 4 labels
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
Posted on Jan 26, 2011
Enlarge font dymo handheld labeler
Please make sure the width of the tape is sufficient. You can select it every time you insert the cassette. If you would like step-by-step instructions, feel free to ring us (see dymo.com for numbers).
^CM
Nov 18, 2013 | Dymo Labelmanager Lm 160 Handheld
Printing issue
You are welcome to contact our help desk. The numbers are at dymo.com. We can arrange a repair.
Dec 31, 2011 | Dymo LetraTag QX50 Thermal Label Printer
I have a dymo letratag labeler and it doesnt print properly. its like the ink is running out
Dymo LetraTAGs are thermal printers, so they don't use ink - Change the batteries and it will fix the problem.
Jan 26, 2011 | Dymo LetraTag QX50 Thermal Label Printer
My dymo letratag prints only bottom half of a name
Your cassette tape has probably become unthread. Take the cassette out of your handheld printer. Make sure that the tape is fed under both claws on each side of the tape. If the tape is only under one claw, your label will not be flat and will only print the bottom half of the letter on your label.
Jan 03, 2011 | Dymo LetraTAG Thermal Label Printer
I have a little blue plastic clip with a slot in it and i'm not sure what it is used for as it fell out when i inserted tape.
That will be the cleaning tool, used to clean the print head of your label printer.
It fell from the compartment lid where you should stick it when you are not using it. The slot is used to fasten it to the lid, so look for a salience in the back of the lid that can fit that slot and press it to fix it to the lid.
Oct 11, 2010 | Dymo RhinoPro 5000 Thermal Label Printer
We have a Dymo hand held office labeler which ran out of ink. How do you replace the ink- This machine hold the 1/2 x 13 tape
No ink required. You just got bad tape cartridge. Replace with a new cartridge. This unit burns the letters into the tape.
Sep 18, 2010 | Dymo LetraTag QX50 Thermal Label Printer
Does dymo letrattag need ink, and if so where does the cartridge go?
This labeler uses Direct-thermal print technology - no ribbons, ink or toner cartridges needed.
May 01, 2010 | Dymo LetraTag QX50 Thermal Label Printer
Not printing ink
The print head needs cleaning. Use a swab and alcohol to clean it. If that doesn't solve the problem, then the heater in the print head needs replacing.
Sep 07, 2017 | Dymo RhinoPRO 3000 Thermal Label Printer
27 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
