Question about Sewing Machines
Repairs on overlocker upper looper has broken and needs a new one and re timed.
  • Sewing Machines Master
  • 11,482 Answers
You should probably take it for service. Although, the looper could probably be replaced by the user, the timing is an intricate issue.
Posted on May 16, 2017
ELNAClub 4D Overlocker sewing Machine . How do I set the timing ??
May be difficult for a DIYer, but try searching for overlocker or serger timing.
Jan 13, 2018 | Sewing Machines
Brother overlock 1034d is not chaining. The upper looper is not passing far enough left to catch the left needle. Makes a "crunchy" sounds some times too.
First re-thread the machine starting with the upper looper(3), then lower looper(4), then the needles(2,1). If that doesn't fix it, it may be a matter of loosening the needle tension. Lastly slowly turn the handwheel and see where the loopers cross. The upper looper should come in just behind the scarf of the lower looper without any contact on the forward motion. Otherwise Your needlebar height could be off. Timing a serger is a very precise process and making adjustments could throw it out even further.
Dec 02, 2016 | Brother 1034D Mechanical Sewing Machine
How do you adjust the timing on a serger? I have a White Speedylock 1634.
There are a lot of web sites & videos dealing with timing. Just search for "serger timing" or "overlocker timing."
Jul 28, 2016 | Sewing Machines
I need help in good tension for rolled hem in empisal 606D overlocker
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Make It Handmade Threading Your Serger or Overlocker
Dec 19, 2015 | Sewing Machines
Loopers jamming
Overlockers require precision timing. Take it in and have it cleaned, adjusted and timed.
Sep 06, 2012 | Sewing Machines
Correct threading for 4 th. Juki ind. overlocker
Overlockers and or Sergers are ALWAYS threaded the same way. Upper looper, Lower looper, right needle, left needle. If you have a model number for your Juki we might be able to find you more information.
The best way to figure out tension problems is to thread each thread in a different color so you can determine which thread is giving you problems.
These machines can be frustrating and EVERY time the thread breaks you MUST start the threading problem from the beginning... upper looper, lower looper, right needle left needle.
Aug 31, 2012 | Sewing Machines
I have a bernina overlocker and whenever I use it the lower looper (marked in red) thread breaks. How can I fix this? It was serviced yesterday and when other people used it before me it worked fine!
Then it's one of two things. First try setting your lower looper tension on 3 and see if that works. If not set it back on 4 and cut ALL your threads and re-thread the machine STARTING with the UPPER looper, then the lower looper, then the right needle, last the left needle if you're sewing a 4 thread overlock stitch. Make sure the threads aren't twisted in the thread guide. Make sure the lower looper thread is OVER the elbow on the upper looper and over the upper looper thread. Let me know if this works. We'll work until we get it fixed!
Sep 14, 2010 | Sewing Machines
How do I change to straight stitching from overlock stitch please? I am using a friends Bernina1015 and she is in New Zealand!
Hi. Take out the looper threads and just leave the needles threaded. And if you want just one line of thread unthread one of the needles.
Of course then your going to have to rethread the loopers later to overlock in which case its important to do them in order.
Upper looper, lower looper, right needle, left. If yours is color coded as most are then the order would be blue, red, green, yellow.
Hope this helped.
Nov 05, 2009 | Bernina Sewing Machines
Timing on a Huskylock 535D surger
the eyes of the needles must line up with lower looper as they pass (timing) the distance between the needle and the looper must be exact. No distance between them and not touching. yep, that tight. they shouldnt move the needle even the slightest amount as they pass each other, yet no space between them.
Feb 07, 2009 | Husqvarna Husky 165
Lower looper threader
check to make sure it is not wraping around the upper looper. just stitch without the material and you will see it. but then you must rethread the upper looper and the lower looper again in the right order. hope this helps
Apr 14, 2008 | Brother 929D Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
