Question about Toyota Sewing Machines
Upper looper on Toyota overlocker - Toyota Sewing Machines
SOURCE: lower looper threader
check to make sure it is not wraping around the upper looper. just stitch without the material and you will see it. but then you must rethread the upper looper and the lower looper again in the right order. hope this helps
Posted on Jun 25, 2008
SOURCE: Lower Looper Shaft
MY LOWERLOOPER HAS SNAPED
Posted on Jul 16, 2008
  • 4 Answers
SOURCE: does not stitch lower thread
Make sure when you thread the machine you have the thread seated into the tension assembly on top, then make sure you have the threading ports locked and the switch in the proper place for each looper threading, the machine will only partially thread if you do not have the port locked and it will even still sew although not properly.
Posted on Dec 07, 2008
kent581
  • 87 Answers
SOURCE: timing on a Huskylock 535D surger
the eyes of the needles must line up with lower looper as they pass (timing) the distance between the needle and the looper must be exact. No distance between them and not touching. yep, that tight. they shouldnt move the needle even the slightest amount as they pass each other, yet no space between them.
Kent
Posted on Mar 19, 2009
  • 300 Answers
SOURCE: upper looper will not saty trheaded to sew what
You have to thread the needles last.
1 - Take the threads out of both needles.
2 - Thread both loopers according to the diagram on your serger.
3 - Thread the needles.
If this fails, you need to bring it to a pro for service.
Posted on Feb 12, 2010
ELNAClub 4D Overlocker sewing Machine . How do I set the timing ??
May be difficult for a DIYer, but try searching for overlocker or serger timing.
Jan 13, 2018 | Sewing Machines
Toyota overlocker sl3000 ; 3rd thread keeps snapping. How do I stop this ?
Third thread--is that the upper looper? Remove all the threads from the machine. Clip them below the thread tree, RAISE the presser foot, and then pull all 4 threads down through the needle. (Never Pull Up!!)
ALWAYS RAISE the presser foot.
Rethread beginning with the Upper Looper, then Lower Looper, then the needles. Be sure to ALWAYS thread in this order!! (On most newer machines, when threading the Lower Looper, always finish with the Lower Looper "draped" over the top of the Upper Looper.)
If a thread breaks, remove the threads and start over from the beginning as trying to fish a thread through the existing threads very SELDOM works.
Verify each thread path is correct.
When threading each thread and to insure the threads are seated in the tensioners, give each thread an extra little tug when going through the tension disk.
Be sure to oil your machine frequently to keep it operating smoothly!
Make It Handmade Threading Your Serger or Overlocker
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
May 03, 2017 | Toyota Sewing Machines
I need help in good tension for rolled hem in empisal 606D overlocker
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Dec 19, 2015 | Sewing Machines
How to threading a 3 thread goldex lorance overlocker?
All overlocker machines are threaded like this.
1. Upper Looper
2. Lower looper
3. Needles right to left.
Dec 02, 2012 | Sewing Machines
Toyota SL3455DS overlocker tension problems
Did you thread in the proper order? Upper looper, lower looper, needles from right to left?
Oct 06, 2012 | Sewing Machines
Loopers jamming
Overlockers require precision timing. Take it in and have it cleaned, adjusted and timed.
Sep 06, 2012 | Sewing Machines
Correct threading for 4 th. Juki ind. overlocker
Overlockers and or Sergers are ALWAYS threaded the same way. Upper looper, Lower looper, right needle, left needle. If you have a model number for your Juki we might be able to find you more information.
The best way to figure out tension problems is to thread each thread in a different color so you can determine which thread is giving you problems.
These machines can be frustrating and EVERY time the thread breaks you MUST start the threading problem from the beginning... upper looper, lower looper, right needle left needle.
Aug 31, 2012 | Sewing Machines
I have a bernina overlocker and whenever I use it the lower looper (marked in red) thread breaks. How can I fix this? It was serviced yesterday and when other people used it before me it worked fine!
Then it's one of two things. First try setting your lower looper tension on 3 and see if that works. If not set it back on 4 and cut ALL your threads and re-thread the machine STARTING with the UPPER looper, then the lower looper, then the right needle, last the left needle if you're sewing a 4 thread overlock stitch. Make sure the threads aren't twisted in the thread guide. Make sure the lower looper thread is OVER the elbow on the upper looper and over the upper looper thread. Let me know if this works. We'll work until we get it fixed!
Sep 14, 2010 | Sewing Machines
How to thread an overlocker - bernina 2500dect
Here's a manual to download:
BERNINA Support Machine and Accessories Finders and Software Support...
NOTE: Be sure to thread each spool in the order SPECIFIED in the manual. Usually the upper looper threads first, then the lower looper second. Make sure when you finish threading the lower looper that the lower looper thread CROSSES OVER the upper looper (and thread) before going under the presser foot.
Nov 02, 2009 | Bernina Sewing Machines
Lower looper threader
Apr 14, 2008 | Brother 929D Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Toyota Sewing Machines Experts
Tally Girl
Tally Girl
xxxxxx xxx
Are you a Toyota Sewing Machine Expert? Answer questions, earn points and help others
