Question about Refrigerators
Model ffhs2622mw figidaire frig ice won't crush clunks loudly
  • 2651 Answers
SOURCE: Always dispenses CRUSHED ice
try removing the ice bucket, and on the back wall is a hole approx 1.5 inches square that the brass bar attached to the rear of ice container inserts into,(you may have to put hte container back in partilaly to look under and watch where it slides into) inside thatcut-out is a plunger that slides up and down activating the crushed/cubed can sick you finger in the hole you should seee a plastic hoop that would catch the brasss bar.Try pushing and pulling hte hoop up and down if it does not move freely, youll need to replace the solenoid assy. if it does, then pull allthe way to the lowest positon and make sure when replacing the ice container that the bar falls with in the hoop itself
Posted on Mar 22, 2008
  • 478 Answers
SOURCE: The Ice maker is stuck on crush
This is a simple thing. the solenoids get rusted and jam stuck in position. you can just clean the device but for all the trouble it should be replaced.
Posted on Mar 12, 2009
  • 744 Answers
SOURCE: kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Posted on Apr 08, 2009
  • 4070 Answers
SOURCE: Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
  • 1126 Answers
SOURCE: only puts out crushed ice
Pull out the ice bin and set aside. On the back wall of the freezer where the auger drive coupling is, to the right and down below the locator pin, is a square opening....make sure that the actuator is in the down position. if stuck in up position, it will always crush the ice. We have had the same problem with our frigidaire. The actuator is connected to the "crushed ice" solenoid.
Posted on Aug 18, 2009
Testimonial: "Your help was wonderful---THANKS"
Ice dispenser wont work correctly
the touchpad goes to a relay which may be out..
Jan 08, 2014 | Frigidaire FRS26RLECS Side by Side...
Compressor is making very loud clunk when shutting off.
I think the wire was kinda expensive. If I were you I would try to save the fridge. I think you should unplug it for a couple hours, take everything out for a while and remove any ice. Once the fridge reached room temp, the refrigerant should have made its way back to the compressor. Plug it back in and see if it makes the noise again.
It might just be the fan in the freezer. I would try the unplug/deice for a few hour method first because it is free before you try to replace a fan that might be bumping ice. Good luck!
Mar 10, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
I got a new french door frig and it wont make ice CUBES. It makes ice and even though the indicator says cubed ice, it comes out crushed. Is there a way to fix this easily. Otherwise i like the frig very...
Try removing the ice bucket and ensure that there is no obstruction (ice cubes stuck inside of metal blades). If no obstruction, then your problem may be in the electronic dispenser control board (if applicable) that distinguishes between cubed and crushed ice. If it appears that the problem is the board, then contact an appliance service company.
Feb 10, 2010 | Samsung RF265AA Bottom Freezer French Door...
Only puts out crushed ice
Aug 18, 2009 | Frigidaire Professional Series PHS68EJSB...
You may be on the right track. Remove the ice bucket and check the square hole behind the ice bucket in the back wall of the freezer. You should be able to move the horizontal rod in it up and down with your finger. If not, it may be frozen in one position. If so, just warm the area a bit with a hair dryer to free it. Replace ice bucket and test. Another thing which may cause that is the ice auger itself may have separated from the drive shaft. (The icemaker itself has nothing to do with making "crushed" ice. It only makes cubes. The cubes are dispensed or crushed and dispensed at the front of the ice bucket using the auger and the metal parts there.) You might also want to verify that the long metal rod (which extends past the ice bucket and into that square hole) is able to move. (it is spring loaded)
Feb 03, 2009 | Refrigerators
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Frididaire Gallery series side by side with ice and water in the door
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 14, 2007 | Frigidaire FSC23F7D Side by Side...
Crushed ice only
Behind the ice bucket is a metal housing that holds the auger motor and solenoid.  The solenoid is bad.  When you go for cubed ice that solenoid should pull up the metal rod on the ice bucket so full cubes will come out.  First check to make sure the metal rod on the ice bucket isn't somehow caught under the solenoid and not letting if move up and down.  You can take out the ice bucket and press for cubed ice.  You should hear a loud clunk noise.  If not then you know the solenoid is not working.
Oct 11, 2007 | Frigidaire FRS3R5EMB Side by Side...
Maytag side by side MSD2735GR
well sometimes it clogs up , when i open the frig door sometimes the ice falls out since the actual cup in inside of frig is full of the crushed ice.
Sep 11, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
