Question about Refrigerators
Turn off water pump to ice maker - Refrigerators
SOURCE: Ice maker
I am having the same problem with mine.
Posted on Jul 15, 2008
  • 218 Answers
SOURCE: Ice Maker not Getting Water
There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
Posted on Jul 23, 2008
  • 12 Answers
SOURCE: Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Posted on Dec 01, 2008
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
SOURCE: Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Posted on Mar 31, 2009
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker -
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
How do you turn on the ice maker
I think ice makers have a power button either a toggle switch or when you look at the top of the ice cube maker you will see a stainless bracket about the size of a pencil lead and as long as the ice cube maker. If the bracket is up then the ice maker is off. It should be down touching or almost touching the cube maker. Another problem could be that you have no water flow to the maker. Line may be frozen. If you find the toggle or push the stainless arm bracket down you should hear the water pump Buzz or hum. Try turning it from off to on but wait about 2 or 3 mins between switching. I hope my info was relevant to your problem. Make sure your water pump is working it's located on the back bottom where the water line goes in
May 11, 2014 | GE GSL25JFPBS Side by Side Refrigerator
Manual icemaker
do you mean drain pump? if so is there water standing in the bin? unstop the drain if not then replace the pump.
Jan 22, 2014 | Scotsman CSW45 15" Ice Maker with 26 lb....
U Line Ice Maker not working at all
if your drain pump is the one you plug your ice maker into and then the pump into the wall plug the pump is full and will not let the ice maker run. must be something wrong with pump
Nov 14, 2013 | U-Line Icemaker
Ice dispenser not producing ice. water not being fed through pump to ice tray
It sounds like you might have a bad fill valve. There are several reasons that an ice-maker doesn't get water. If the freezer isn't cold enough, the ice-maker thermostat will not allow it cycle. There are two different styles of ice-makers. Pull the white cover off of the ice-maker, if you see two gears the you have one of the earlier models. Turn the smaller of the two gears counterclockwise slowly until the gears start to turn by themselves. Now if you do not have the two gears under the cover, then you have a modular ice-maker. There are several holes in the brown plate. Each hole will have a letter beside it. Jumper between the T and H holes until the ice-maker starts to turn by itself ( you should hear a click if you'll listen closely). Now that you ave cycled the ice-maker, check and see if there is water in the ice tray. If you still have no water then change your fill valve. If you do have water then its usually cheaper to replace the actual ice-maker. Be sure to check the temp of the freezer, most ice-makers will not cycle above 10F degrees. Most ice-makers are around $130. Most valves are around $50. I hope this helps you solve the NO ICE situation.
Mar 20, 2011 | Freezers
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
May 05, 2009 | Kenmore Refrigerators
Thin Ice on Whirpool Ice Maker
If  The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Apr 05, 2009 | Whirlpool Freezers
Jenn Air JCD2389GES ice dispenser problem
You could have a layer of solid ice at the bottom of your icetray. Remove icetray. Remove any ice in bottom. Reinstall. Be careful there is a connection on the rear of the icetray, you may have to turn it to get it to mesh correctly. Fill with ice and it should work fine. Good Luck.
Feb 24, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
