Question about Irons
Where can i find a replacement electronic temperature control for my G1490F iron ?
2 Suggested Answers
  • 3 Answers
SOURCE: Shark Intelligent Electronic Iron - how to clean the soleplate?
Try a "magic eraser". They're minimally abrasive. Then run the iron over a piece of waxed paper and then on a cotton cloth or rag.
Posted on Apr 28, 2010
Steam iron turns itself from hot temperature to cool
1) test the electronic control for defective and follow the next steps. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jun 11, 2013 | Irons
The temperature of the boiler is not controlled normally and the safety valve opens. I suspect that the temperature control sensor is not functioning properly, and if this is the case where can I find a...
see this causes and use the common sense. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Sep 19, 2012 | Rowenta Irons
Why light blinks then goes off when switch is still in the on position
The thermostat in the iron controls the temperature of the iron. The red light indicates when the power applied to heat the iron which is set by the temperature dial on the iron. When it reaches the correct temperature the thermostat turn off the power and that is when the red light switches off.
Jan 15, 2012 | Irons
My shark steam iron is leaking when ironing
It is quite possible that this is a defect in the shark G1490F... I had the same problem and it was a crack in the water holding tank caused by tightening the two front screws (hidden) that hold the tank to the base... It seemed fine at first but after a full heating it developed a crack where it had been weakened when it was assembled... I suggest returning it or if warranty is up , throw it away and get something else..
May 23, 2010 | Euro-Pro Shark GI490 Iron
Apr 26, 2010 | Euro-Pro Shark GI490 Iron
The iron is dripping rusty water
this iron has had it . it has rusted throuh the element and the rust s iron oxide . .. not repairable .. // replace it . as it will cost less .. mm
Jan 15, 2010 | Euro-Pro Shark GI490 Iron
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Tefal FV9255 Iron
i do believe is something wrong with the thermostat or the electronic board.That model i do believe(but i`m not sure) have a small circuit board controlling the temperature and the safety.Make sure also your thermostat handle is working properly because sometimes the connector between the handle and the thermostat can get bad and not adjusting the right temperature
Fabio
Jun 20, 2008 | Tefal UltraGlide 1759 Iron
Irons Logo
63 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
