Question about Cameras
Is the Nikon SB 800 compatible with the Olympus E Volt 510 ?
  • 13,433 Answers
It works with every Nikon camera made for the past 40 years.
Posted on Jul 25, 2009
Can I use Nikon SB-22s speed light with my Nikon digital SLR D5000? Is that compatible? I bought SB-22s for my previous Nikon film camera. Thank you.
You should be able to use your SB-22 with your D5000, however you can only use it in the manual mode since it is not a TTL speed light. That means you will need to manually set both the camera and the flash unit. I have done that successfully with an SB-25 on both my D800 and D90 in a pinch, but you should consider investing in either an SB-700 or SB-910. They are allot more versatile.
Oct 26, 2013 | Nikon Speedlight SB-22S TTL Flash
What the best flash for d80? s sb 800 & 900 compatible for it?
The best flash for YOUR D80 is the one that best suits YOUR needs. Both the SB-800 and SB-900 are compatible with the D80. So is the SB-600, which is lighter and smaller.
Jan 09, 2011 | Nikon D80 Digital Camera with 18-135mm...
What setting should the camera be on for an
That depends on the flash. If it's CLS-compatible (Nikon SB-400, SB-600, SB-800, and SB-900) you can use it in any exposure mode (except flash off, of course). The easiest flash mode is Auto-TTL, though some of the other modes will give you better control under certain situations.
If it's not CLS-compatible, then you'll have to take it off Auto-TTL. If the flash has a sensor, you can let the flash control itself (assuming it's at the same distance from the subject as the camera). Otherwise you'll have to go manual.
May 12, 2010 | Nikon D60 Digital Camera with 18-55mm lens
I want to know how to use the 952AF/Nik with the nikon d200 using multi flash units with the commander mode set to channel 1
The vivtar 952AF flash is not compatible with the D200 in commander mode. Only the Nikon SB600, SB-800, SB-900 will work with that camera wirelessly.
Oct 11, 2009 | Cameras
Nikon speedlight sb-800
THE PROBELM COULD BE IN MAIN BOARD OR THE BATTERY CONATCTS NEED ADJUSTING
Sep 22, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb-800 sync
Make sure the slave is not set to rear curtain or slow flash. Otherwise Send that back to Nikon for service. http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Aug 02, 2008 | Nikon Speedlight SB-800 TTL Flash
NIKON SB800 IN SOFTBOX
Hello..
Sporadic off camera flashes triggered with pocket wizards will not be as obtrusive as you may think. IMP, It's just as obtrusive as the onslaught of small digi cam flashes that usually occur..Cheerss!!....
Jul 24, 2008 | Nikon Speedlight SB-800 TTL Flash
SU-4 on sb800
Unlock The Superslave in Your Nikon SB-800 http://strobist.blogspot.com/2007/08/unlock-superslave-in-your-nikon-sb-800.html
Dec 23, 2007 | Nikon Speedlight SB-800 TTL Flash
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
