POWER IS OK TO DISPLAY PANEL BUT IS NOT WORKING
The back panel of the motherboard is not working but when I test the memory its ok and when I put the video cord in the back panel there's no display. and I try to put a video card in the agp or p
Hello download the manual here:
http://www.msi.com/product/mb/PM8M-V.html#/?div=Manual
Look here also:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Check the power supply, and all your power connections again.
Try to reset the cmos by removing the battery, and inset it again.
Look also for bad caps on the mainboard:
If they look like this,scrap the mainboard.
It does not pay, to let them be changed.
Good luck
Jan 21, 2013 | MSI PM8M-V Motherboard
Samsung RSH1DBBP Digital Display problem
The display panel has damaged. It has to be replaced by same type and number. There is no repair to it. OK.
Feb 01, 2012 | Samsung RSH1DBBP (19.1 cu. ft.) Side by...
Change operating system from Spanish to English
Im assuming that the question is the operating system, commands, etc are all in spanish. You did not specify your operating system so unsure about what version or manufacturer. The instructions below will work for Vista... similar instructions can be done in XP and Win 7.
  1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab.
  3. Under Display language, choose a language from the list, and then click OK.
  4. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  5. Click the Keyboards and Languages tab.
  6. Under Display language, choose a language from the list, and then click OK.
  7. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  8. Click the Keyboards and Languages tab.
  9. Under Display language, choose a language from the list, and then click OK
May 17, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
How do I reset the ink level indicator on a HP deskjet 4280 using CC640WN black and CC643WN cartridges?
OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech...
James Cowan: HP error code 0xc18a0001
Earnest: I will assist you in this regard. I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
James Cowan: Correct
Earnest: May I have the model number of All-In-One you are using?
James Cowan: c6250
Earnest: Please let me know the room temperature in which printer is replaced
James Cowan: 67 degrees F
Earnest:: OK. Please perform the below steps on the front panel of the printer to resolve the issue
James Cowan: OK
Earnest:: Press and hold the "left arrow" key. Press the "Setup" key and release both keys, display should say "Enter Special Key Combo". Press and release the "OK" button
Earnest: Please ignore the above steps
James Cowan: OK yes nothing seemed to do anything
Earnest: Please perform the below steps on the front panel of the printer. Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo". Press and release in sequence"Red Eye Removal", "Print Photos", "Red Eye Removal"
Earnest: Display should say "Support" and display the FW rev (something like R0616R)
James Cowan: COxxFN0723BR
Earnest: OK. Press and release the right arrow button until the display says "System Configuration Menu"
James Cowan: OK
Earnest: Press and release the "OK" button
James Cowan: OK and it says hardware failure status
Earnest: Display should say "Hardware failure status: Clear. Press OK to clear". Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. Please do not try to print at this stage
James Cowan: OK
Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Let me know once you are done with the above steps
James Cowan: OK its unplugged
Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message "Use POWER button to shutdown the printer" followed by "Press OK to continue". Press OK
James Cowan: OK
Earnest: Let me know the message displaying on the front panel of the printer
James Cowan: printer preparation occuring - do not interrupt
Earnest: OK
James Cowan: OK its done
Earnest: Let us print a self test page from the printer now
James Cowan: OK deal
Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray
2) Make sure that the printer is on and loaded with unused plain, white paper
3) Press Setup. The Setup menu appears
4) Press the down arrow button to select Tools and then press OK
5) Press the down arrow button to select Self-test Report , and press OK. The self-test report prints
James Cowan: OK printing
Earnest: OK, please check whether all the colors pritned perfectly on the test page
James Cowan: Perfect
Earnest: Great... Cheers!!!
James Cowan: Thank you very much
Earnest: Now you can continue using the printer.
Jul 19, 2009 | Office Equipment & Supplies
Error 79 hp 3300
OK I had the hp error code 79 for HP 3300 problem and here is the conversation I had with the tech...
James Cowan: c6250
James Cowan: OK
James Cowan: OK
James Cowan: OK
James Cowan: OK
Earnest: OK
Apr 24, 2009 | HP Office Equipment & Supplies
60.40 Error Message on HP Laserjet 5025 MFP printer
OK I had the hp error code some problem and here is the conversation I had with the tech...
James Cowan: c6250
James Cowan: OK
James Cowan: OK
James Cowan: OK
James Cowan: OK
Earnest: OK
Feb 22, 2009 | HP Office Equipment & Supplies
Zebra 4M Plus - There is no display info when powered on.
Ok so the printer is calibrating and printing which means the fault lies with the display, or power to the display pcb. Check the fuse on the mlb, if that is ok then order p/n G79302M (display panel)
Dec 31, 2008 | Zebra Z4Mplus Label Printer
Dacor ERDS30 clock and display OK, all bake buttons non responsiv
Most likely the interuption of power is what caused the problem. try shutting down the circuit breaker that controls the range for 30 minutes then turn it back on if this does not reset the electronics. You may need to replace the keypanel and /or electronic control as either or both may have been damaged by the power surge.
Dec 31, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
NO FRONT PANEL DISPLAY
If the display processor has failed, you are out of luck, but sometimes it is just the backlighting (bulb or LED) for the LCD display or if if nothing in that circuit has voltage, then you can usually track down the power regulator for it and fit that.
Hope Ya Fix It!
Feb 08, 2008 | Audio Players & Recorders
16 people viewed this question
k24674
jasbo
jasbo
