What to use on open boil or carbuncle to heal?
Have boil (I think is a boil or carbuncle) popped and draining but there is some stringy white stuff (feels like wet cotton) that is sticking on to the wound and is hard to take it off)
No never did tell how long to boil the corn
You don't boil corn for making popcorn, it must be dry as taken from the bag. If needs a certain amount of moisture to pop, but not boiled.
If you want to boil corn kernels or corn on the cob, 20 minutes in boiling salted water will cook it perfectly. Frozen corn, only about 10 minutes, canned cream corn, just until it simmers.
Noel, I see you adding stuff in the Comment boxes, but you need to say what information you need after the stock phrase. Usually we have some idea of what the OP is on about, and you use that box to request specific information, or just move on to the next post. Thanks for helping out though.
Andrew - Fixya moderator
Nov 09, 2016 | Kitchen Appliances - Others
2008 ford edge water wont drian from a/c tubing cant locate how to blow out leaves collected there
under the truck there should be a little black tube. Using some light gauge wire, Stuff it up inside the tube and get the debris free from is, after this you will need to open the HVAC system ( I like to go through the blower motor opening, which you will need to remove the blower motor) and vacuum out the debris.
Oct 27, 2011 | 2000 Ford F250 Super Duty Crew Cabs
When I try to edit a document and save it to the USB with another name, I cannot do it. A message keeps popping up that says to remove the overwrite protection. How do you do this?
i think you use quick heal total security antivirus,
if yes,
then open quick heal,
click on external drives and devices,
Aug 11, 2011 | Computers & Internet
My reserve coolant is boiling but its stay full ...why???
Might be mostly water. Check the gravity of the coolant, one of those little floaty ball things at walmart, $2, If it is not up to par with 50/50 coolant, fill it up or drain some of the water out. It is building up too much pressure and releasing the boiling stuff into the reserve tank, the cap could be bad, not tight, could be a blown head gasket, check this stuff out. Look for oil in the top of the radiator, steam out the exhaust, usually loses water though. Water boils at 220 and coolant 260 in a closed system, keep an eye on the temp gauge, do not let it over heat. It will be shot if it does. Hope this helps.
Jun 28, 2011 | Dodge Caravan Cars & Trucks
Leaking in front of the engine.. The leak is about 2 inches above the intake gasket and around the thermostat housing gasket.. It's coolant and if I turn my car on it overheats within 10 minutes.. The...
Drain the coolant, undo the thermostat housing and remove the thermostat. Drop it into a pan of boiling water and watch closely. The thermostat should pop open. Take the pan off the boil and watch for about ten minutes, the 'stat should pop closed. If the 'stat does not respond then is is dead and new one is required, along with a gasket. Renew the coolant if rust colored. Top up thoroughly squeezing hoses to encourage air bubble removal.
Feb 09, 2011 | 2002 Chevrolet Impala
When cold it shifts fine, but when the weather is hot and when running the air conditioning it is very difficult to get it into 1st gear. I have changed the master and slave cylinders, and even had the...
could be a little vapor lock in the hydralics. get new fluid **** out old stuff with turkey baster then refill with new bleed screw at trans and let half of the fluid just drain out untill clear as the new stuff keep it filled while doig this so no air will get in. moisture in brake fluid greatly lowers boil point making vapor lock more common
May 29, 2010 | Chevrolet C1500 Cars & Trucks
Cannot get the drain to drain in the freezer. tried boiling water but it isn't draining
Based on the description it looks you've got some non-liquid stuff got into the drain and you will need something more forceful than the boiling water. What you will have to do is to take the drain out and push the clog out.
Here is the description of compatible fridge:
Nov 05, 2009 | Refrigerators
My computer is also infected by the FU virus!!!
Dear Sir,
I think you are facing a virus problem if it was a virus problem then go to and download Quick Heal Total Security (PC Mobile Scan and Data Theft Protection, Anti Phishing) or Quick Heal Anti Virus Plus mail me if you're facing any problem
Thank you
Bye bye
Sep 28, 2009 | Microsoft Windows XP Home Edition
Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 15, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
