Question about Casio Watches
How to set/delete alams on RT1MD watch - Casio Watches
Instructions or user guide( NOT MANUAL) for marathon watch WR50M
Download the pages and then delete the unnecessary pages you won't ever use.
Apr 10, 2017 | Watches
Citizen Calibre 2100
seems your watch needs cleaning/alignment. button is either jammed inside or misaligned maybe inside.
if you could manage to open it carefully and figure out why the button doesn't depress then do it on your own. or you could have it to a reliable service person/center to have it fixed. request for a repair warranty, and if your find it satisfying (warranty) let then fix it. ask them later why was it behaving like that.
Feb 18, 2008 | Watches
All I want is to delete 2 videos my grand son doesn't watch
Just press the video for a moment then there should be options to select then select delete or go into files and select from the drop down menu delete files and select the two that are unwanted!
Jan 16, 2015 | Watches
I have a full memory need to delete files and forgot how
Here are some steps to delete a file in your Polar watch.
Deleting a file
1. In the Time of day display scroll up or down until FILE is displayed.
2. Press OK to enter the File mode.
3. Scroll up or down until desired exercise file is displayed. Press and hold
the signal/light button. DELETE FILE and file number are displayed.
4. Press OK. The wrist unit confirms if you want to delete a file
(Are you sure).
5. Press OK to delete the selected file.
6. Press stop to exit the file. Wait appears. The wrist unit rearranges your
file, which takes few seconds.
7. Repress stop to return to the Time of day display
Deleting all files
2. Press and hold the signal/light button. DELETE FILES is displayed.
3. Press OK. The wrist unit confirms if you want to delete all files
(Are you sure).
4. Press OK to delete all exercise files.
5. Press stop to return to the Time of day display
For more information, refer to manual of the watch.
I hope this will be able to help you.
Thank you for choosing Fixya.
Mar 16, 2011 | Polar S S625X Wrist Watch
How can get sound on my iroman 8 lap watch after changing battery. I wander if there should be a tape in the back cover and if yes to what extent it should cover. when I set my alam I see the fainting of...
mcdevito75 here, It"s possible the NEW battery in your watch is weak from an extended shelf life, I'd return to the place the battery was installed and ask. Also you can go over your watches functions again as the watch has to be re-set once the battery is changed.
Jul 15, 2010 | Timex Watches
I have replaced my battery in my Oakley sports watch. How do I set the time and date? The watch has a four buttons around the side - at 2 o'clock position the button is STOP/RESET.FORWARD, at 4 o'clock...
Use this link:
http://oakley.com/customer_service/support/watches
If you can not find your particular watch here, email them using same site and ask for instructions to be sent to you.
Rate me, please.
Aug 14, 2009 | Oakley Watches
Turning alarm offI
how do I turn off the hourly setting
Jan 19, 2009 | Casio DB360G-9A 30 Pages Telememo Watch
Setting the time
Dear Sir,
It appears that the watch was malfunctioning which I thought was due to a change of battery being required.
(It was running slow and giving the wrong time - so my mother told me)
I subsequently found instructions for the watch on an internet site, changed the battery and the watch is still failing to set to the U.K. time zone therefore, I deduce that it is a failure in the watch rather than the need for a new battery or ranything I have or have not done.
Please delete my question from your system
Thank you.
Regards
Jan 17, 2009 | Bulova Watch
Aqualite Alarm Chronograph 4 button watch
good after noon ! press the adjust button hold it up to 3 second when the digit is blinking thats time to set press the mode to select the digit that you want to change after that press the stert or reset button to change no digit ! thank you ! god bless !
Aug 28, 2008 | Watches
Problem with the time setting
The only info which continually flashes is a dart and the letters chg
Feb 02, 2007 | Casio G-Shock G510D-1AV Wrist Watch
Watches Logo
62 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
