Question about Coffee Makers & Espresso Machines
Just descaled citiz machine and both buttons are still flashing .will not cancel after twin press. have tried factory reset to no effect can you help please Bryan Marlow
SOURCE: descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Posted on Aug 17, 2008
mirran
  • 515 Answers
SOURCE: Incanto Cappacino I was descaling my
Fill the water tank with water, open the steam knob and when the water comes out, take off the water tank and let the machine go to it stop.
Close the steam knob and put back the water tank.
Open the steam knob again to get out the air in the system.
Hope this will help you.
/Mirran
Posted on Aug 23, 2008
flexion1
  • 737 Answers
SOURCE: how do you reset sharp xe-a302 cash register to factory defaults
Hi.
I would not recommend doing this unless you are certain that it is the cause. I have never had memory corruption in this series before, so I would strongly suggest it is being caused by another factor such as spillage in the keyboard.
Can you tell me exactly which buttons are showing the problem and what happens when you press them. Can you still make sales with the product buttons?
Mark
Posted on Nov 29, 2008
SOURCE: Flashing red light. Nespresso Citiz & milk coffee machine.
problem is overheating at a single point in the bottom of the milk container. Try cleaning the milk residue after each time you use it and the flashing red light disappears. This is a design fault. Nespresso are happy to keep marketing the Citiz but there is no fix - so the Nespresso "mess free" coffee machine is a bunch of flannel - good coffee all the same!
Posted on Sep 05, 2010
SOURCE: After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
Posted on Feb 05, 2011
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
HOW TO ADJUST WATER QUANTITY AS THE LONGER BUTTON WILL NOT ADJUST, SHORT CUP IS OK
Try resetting to factory settings by holding both buttons down while turning the machine on - hold till lights stop flashing. Then programme both espresso and lungo buttons again in the usual way.
Hope this helps!
Mar 13, 2015 | Nespresso CitiZ & Milk Espresso Maker
My nespresso is only creating 3-4 oz of coffee using the 6 oz button. Have descaled with no change. Any ideas?
Try holding both the buttons down and then turning the machine on while still holding the buttons till they stop flashing - usually about 2 - 5 seconds. This will reset to factory settings. Then you can reprogramme the Lungo button if necessary, by holding it down white the coffee is being extracted, till the amount you want is processed. The machine will remember this till you reset to factory settings.
Dec 06, 2014 | Nespresso Citiz C110
Red triangle will not stop flashing even after I descale
I have the Illy coffee maschine x7.1 and I'm trying to do the descaling (since the litle triangle sign is flashing), but power button doesn't start flashing after I push the coffee and steam button together (as indicated in the manual). Any suggestions what I should do, that the on/off button would start flashing?
Jan 25, 2014 | Illy Francis Francis X7.1 iperEspresso...
Nespresso citiz won['t exit descaling mode
I had the same issue, and took it to the repair shop, where the guy did the same thing, just pressed both cup buttons for 3 seconds. It worked. He said the Lungo button had to be pressed a little harder, as it had some connection problem, and thats why it didnt work for me. If you have the same problem, the machine will start buzzing for about half a sec if you press the lungo button while in descaling mode.
Nov 29, 2012 | Nespresso Citiz C110
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
No coffee comes out, only water despite capsule inserted. Capsule doesn't pierce at the front.
Hi Sandrine, i have the same problem with my Citiz paris limited edition. Did you find a solution to that?
May 28, 2011 | Nespresso Citiz D110
Nespresso clitz's light is keep blinking. I pressed both button but not working, I turned it on and off and make sure wate container is placed correctly.
It sounds like you've put it into descaling mode. Hold down the "large" button for a second or two and water should start coming through. Press the large button again to stop it. Lift the capsule eject handle and put it back down. Then hold down both buttons for about 3 seconds to exit descaling mode.
Dec 10, 2010 | Nespresso Citiz D110
We have a Nespresso Citiz C110 which today decided to start having problems. It starts its cycle perfectly but as it is filling the cup the water goes cold and after a few seconds switches the pump off...
Sounds like it needs to be descaled. If this has not been done for a very long time, the scale will have affected the thermoblock and I may not return to full function. I only use Nespresso descale kit (not vinegar).
Jun 21, 2010 | Nespresso Citiz C110
May 16, 2009 | Nespresso D290 Espresso Machine
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
