I have disc for Brick Bustin Madness. How do I get it to
Work on my Windows 7?
Ultra slim LG tv not bustin
TV not bustin? What's it?
Jun 17, 2015 | LG Televison & Video
Reset windows 7 password hp
You may try the below steps to reset or recover the windows login password:
1) Insert either your Windows 7 installation DVD, or a Windows 7 System Repair disc, into your optical drive and then restart your computer. If you have either on a flash drive, that'll work too.
Note: If you don't have original Windows 7 media and never got around to making a system repair disc, don't worry. As long as you have access to any other Windows 7 computer (another in your home or a friend's will work fine), you can burn a system repair disc for free.
2) After your computer boots from the disc or flash drive, click Next on the screen with your language and keyboard choices.
Tip: Don't see this screen or do you see your typical Windows 7 logon screen? Chances are good that your computer booted from your hard drive (like it normally does) instead of from the disc or flash drive you inserted, which is what you want. See the appropriate link in the tip from Step 1 above for help.
3) Click on the Repair your computer link.
Note: If you booted with a system repair disc instead of a Windows 7 installation disc or flash drive, you won't see this link. Just move on to Step 4 below.
4) Wait while your Windows 7 installation is located on your computer.
5) Once your installation is found, take note of the drive letter found in the Locationcolumn. Most Windows 7 installations will show D: but yours may be different.
Note: While in Windows, the drive that Windows 7 is installed on is probably labeled as the C: drive. However, when booting from Windows 7 install or repair media, a hidden drive is available that usually isn't. This drive is given the first available drive letter, probably C:, leaving the next available drive letter, probably D:, for the next drive - the one with Windows 7 installed on it.
Hope this helps..
Feb 18, 2015 | HP Computers & Internet
I have a problem with starting up my computer, when i press the turn on button it comes up with windows boot manager tells me to do 1. Insert your windows installation disc when i enter my windows 7 disc...
Hi there !
You operating system is corrupted and needs to repair or reinstall the operating system. But I suggest just run the repair mode.
If your windows 7 installation disc is not working, it means the Windows 7 installer DVD is not working properly, maybe the DVD have too much scratches or due to bad copy of installer DVD, (it is not working in CD, use DVD) try to use other Windows 7 installation disk and surely it will run the Windows 7 DVD set up menu.
I hope it helps you.
Jan 18, 2011 | HP Pavilion dv6000t 15.4" Notebook Laptop...
How download full version of game
In order to get the full version of Microsoft Midtown Madness, you must buy it as a CD-ROM, since you cannot download it directly. This game is probably out of stock in stores (it is several years old) so your best bet is to buy it here: http://www.amazon.com/Microsoft-Midtown-Madness-Pc/dp/B00001LDBV.
Mar 09, 2010 | Microsoft Midtown Madness for Windows
Cant look inside cars on mm2
You can change your games camera views from options tab.
Feb 21, 2009 | Microsoft Midtown Madness for Windows
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
