What does hardware error 0502 mean - Office Equipment & Supplies
SOURCE: Hardware error message
push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.Because my printer the carteage was slaming up against the printer and I did this and hardware 0502 went away. I called the techs they told me to shake it.That didn't fix it.
Posted on May 15, 2008
IrishDruid
  • 2712 Answers
Cause
The encoder strip may have gone out of range of the sensor, or it might be dirty.
Resolution
You need to check the encoder strip on the printer. This is a clear strip running the length of the printer, above or behind the cartridge carrier.
Check the encoder strip
  1. Switch off the printer using the power button.
  2. Disconnect the power cable from the back of the Lexmark X5100/X6100 Series.
  3. Leave the power cable disconnected for 30 seconds.
  4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
  5. Take out both cartridges.
  6. Place an index finger on the encoder strip on either side of the cartridge carrier.
    The red arrow points to the encoder strip. Click here
  7. for an enlarged view.
  8. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
  9. Lightly press the strip first to the rear and then forward, if necessary.
  10. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
    Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones to clean. Use a dry tissue.
  11. Reconnect the power cable and switch the printer on again.
  12. Perform the hardware test first without cartridges and then with both cartridges. Click on the applicable document below. How to Perform the Hardware Test on the Lexmark X5150
    How to Perform the Hardware Test on the Lexmark X6150/X6170
  13. Make a standalone copy.
  14. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Posted on Sep 28, 2008
namzyanzy
  • 435 Answers
SOURCE: my lexmark x6150 says hardware error 0502
Hardware Error 0502 on LCD Display
Cause
Resolution
    2. Disconnect the power cable from the back of the printer.
    7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
    8. Lightly press the strip first to the rear and then forward, if necessary.
    9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
      Click here for an enlarged view. The contacts on the back of the cartridge carrier are the ones you need to clean. IMPORTANT: Use a dry tissue.
    10. Reconnect the power cable and switch the printer on again.
    11. Perform the hardware test, first without the cartridges and then with both cartridges. Click on the applicable article link below.
    12. Make a standalone copy.
    13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Thank you
Posted on Feb 14, 2009
SOURCE: what does hardware error 0502 mean? thanx
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an errorbf27252.jpg
Posted on Jan 03, 2010
pineworks
  • 4041 Answers
SOURCE: Hardware error code 0502 how to solve this
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 25, 2010
Testimonial: "thank you very much.sofar it works !!!! 4 stars !!!!"
What does "Hardware Error 0502" mean?
The shaft that the ink cartridges travel back and forth on get buildup on it. If you clean it, your problem should go away...
Your answer and fix is here:
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Jan 21, 2011 | Lexmark X6150 All-In-One InkJet Printer
Printer displays hardware error 0502 wont print " HELP "
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
.... most of the time, it's the encoder strip that is giving the problem..
goto
http://support.lexmark.com/index?userlocale=EN_US&locale=EN&page=content&segment=SUPPORT&productCode=LEXMARK_X5150&id=HO2707
May 24, 2010 | Lexmark X5150 All-In-One InkJet Printer
Error code 0502 hardware error on dell printer
i once fixed the hardware message by putting the tape back on the back of the cartridge...then fixed the perpetual paper jam message...
Feb 19, 2010 | Dell 922 All-In-One InkJet Printer
Getting hardware error 0502
Hardware Error: 0502. On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error.
send you the link where you can figured out
Thank you for using FixYa!
Do have a nice day and please remember to rate this solution.
Best regards,
sourav
Jan 05, 2010 | Lexmark X6170 All-In-One InkJet Printer
What does the error 0502 mean when you are trying to make a copy.I am using the Lexmark X6170 All in One..
Hardware Error: 0502. On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a kleenex and the problem seems to go away. Somehow it presents a drag on the cartridges and causes an error. This from Clem.
Dec 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
Printing error says: Hardware error 0502 (?)
he real answer is given by a person called ‘clem’: 98393885_c4f82c99a9_m.jpgHardware Error: 0502.
Clem
(from fixyourownprinter.com)
This works! Clean the ****** with a paper towel (another page talks about re-lubricating the thing, but that was not necessary in my case). The towel will be black (ink residu, presumably), but there you go printing to your heart’s desire again.
Jul 12, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X160 is not printing at all or receiving Faxes. The error that keeps coming up is Hardware Error 0502. Please Advise.
ok sir pls see the link this is the helpfull for the error 0502 in lexmark x160 all in one inkjet printer...ok
Apr 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Lexmarx X5150
see on this site. I had the same problem before 15 minutes and it helps :)
Feb 15, 2009 | Lexmark X5150 All-In-One InkJet Printer
20 people viewed this question
jasbo
jasbo
