Question about Advance Office Equipment & Supplies
Error code E000020-0360 IMAGE RUNNER ADVANCE - Advance Office Equipment & Supplies
  • 67 Answers
SOURCE: Canon Image runner C 3200 printer gives error code E000677-0080
your quickbooks file is in the wrong format example tiff or pdf let your it know they can change it to the correct file format
Posted on Aug 19, 2008
SOURCE: about error code
cannon ir 5000 copier give me error e 0061 & e0069 what the problem and the solution
Posted on Oct 15, 2008
color_50
  • 22 Answers
SOURCE: ROM Error for Canon Image Runner 2010F
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 2010F FG6-9454-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Posted on Mar 14, 2009
SOURCE: Cannon image runner 2200 error code E000002-0000,
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Posted on Sep 26, 2009
57 varieties
  • 1653 Answers
SOURCE: canon image runner error code E000000-0000
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
Posted on Oct 13, 2009
WHAT IS MAKING ERROR CODE E000020-0360 CANON ON A IMAGE RUNNER ADVANCE
Hi . To help you out we need to know the model number of your machine . I assume its a color copier But it seen to be a drum related issue.
May 16, 2017 | Canon Office Equipment & Supplies
Canon error code E000732-888
Hi, that error indicates there a internal comunication error between electronic boards, i suggest to get technical support.
May 02, 2017 | Canon Office Equipment & Supplies
Canon image Runner 2202 error code E000-0000
Aynalem, Canon image Runner 2202 error code E000-0000
Aug 10, 2016 | Canon Office Equipment & Supplies
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Canon Image runner photocopier
It is very easy... What code is it? It may not be resetable with out replacing a part... Need more info...
Jul 07, 2008 | Canon imageRUNNER 210S Copier
Image Runner 210S
it is a fuser problem:-you have to check-.
1-low temprature due to blown lamp(change it).
2-thermal switch(reset it)by pressing on it.
3-ac driver problem(heater control board.
Apr 20, 2008 | Canon Image Runner 3320I Copier
62 people viewed this question
Top Advance Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Advance Office Equipment and Supply Expert? Answer questions, earn points and help others
