Question about Smeg Refrigerators
  • 1462 Answers
SOURCE: fridge freezer
did your friend use a knife to prize off lumps of ice? i bet he/she did and has punctured the evaporator. if so, not repairable
Posted on Jul 05, 2008
  • 1224 Answers
SOURCE: Not Freezing/Cooling - A Red Glow...
also under durland there he is right
if it were me i would check the obvious under the fridge first like a rodent had gotten in and chewed your wires threw in which moister effected the fridge to heat out you could also have bad power unit
also has this unit been on its side this would lead to freon clog and make an over load in fridge if you try and start it after its been fixed or moved
when you move a fridge move upright and if you have to move on its side let set for 48 hours before using fridge freon can clog and cause a back up and this is where you get the glowing from over heating cause of the clog
Posted on Jul 07, 2008
  • 998 Answers
SOURCE: Kenmore won't cool down.
I you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Posted on Aug 15, 2009
  • 1218 Answers
SOURCE: freezer not freezing
Is it running? You might need to put your ear up to machine, to hear it, They run very quitely.
If not running, could be a bad cold control (thermostat), or defective relay and overload mounted on the compressor body.
If the compressor is running but no cooling, then you're in serious trouble unless,
The unit is 5 years old or newer. In that case you have factory warranty on what is called the sealed system. Contact the dealer in that case for service. Service should be free.
Posted on Oct 30, 2009
Testimonial: "it is what I suspected. You saved me a $100.00 service to tell me this. Thanks"
SOURCE: HP Officejet Pro - Printer Door Open Light Stuck On
There is a problem with the proximity sensor for the top door. I have took mine off and soldered the connections over to trick it into thinking the door is closed all the time. I am trying to source a new part
Posted on Jan 11, 2010
Red light flashing will not charge battery have left over night with no result
Sometimes, this is a result of a battery that is too cold (below freezing-warm it up). Sometimes it can be too hot (discharged under heavy stress-let it cool down). Sometimes there may be insufficient voltage, I have had problems in older houses, get closer to the electrical panel to plug in, or you may have to wait until you get home. Red flashing may mean charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been dropped or hit the floor the coil inside could have broke loose and damaged the charger requiring it to be replaced. Below is an unconventional way to charge the battery if the charger is no good. BE CAREFUL
how to charge broken makita BL1830 Li ion battery
Mar 12, 2015 | Makita Cc300dz 10.8V Li-Ion Cordless Tile...
Probably be cheaper to get new one, it has probably had the compressor fail or a leak in the cooling system.
Sep 16, 2017 | Smeg FR148A Refrigerator
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The freezer on our kenmore fridge keeps freezing up and then the fridge doesn't cool. It's a bottom freezer style. We have to unplug it and let it unfreeze in order to get it working properly again but it...
defrost problem, check defrost thermostat on evap coil by removing the back panel in freezer for continuity, if open, replace. check heater in the same fasion, if open, replace. if both are ok, replace defrost timer, or adaptive defrost control.
Jul 01, 2009 | Refrigerators
Its not freezing!! keeping things cool, but not freezing
I would definitely start by checking if the fan is working. Note that the fan is switched off when you open the door, so you need to press the door switch and then check if it is working. If not, that will be the problem.
Apr 15, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
Smeg A2 - Oven gets too hot
is there a heat probe inside the oven? sound like you owen is overheating. i would check the TOD, if the oven has one. this thermostat regulates the temperature and if it's "open" it needs to be replaced.
Sep 13, 2008 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Refrigerators Logo
82 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
