Our ADSL line is very very slow, how can we fix it? This seems to be a continuous problem. Our line number is 0448734310. Please assist
My M1255nf works fine except that since we moved last month, when I get ready to send a fax the line is very noisey even with the phone line removed. I tried replacing the fax card but still same noise. I...
Do you have ADSL internet in your new place? If so you will need an ADSL filter plugged into the phone outlet and plugged into your fax machine. so it would look like phone wall jack--->filter-->fax machine.
ADSL internet creates it own jabber or digital noise in the line and the filter will stop your a analog device from hearing the noise. If you don't have a filter for your phone as well, you should get one. Without filters your ADSL internet will be slower as well. Your ADSL modem should have came with at least 4 filters, if not they can be purchased at your local Bestbuy, staples or computer place. NOTE: Filters only work if you have ADSL or DSL internet.
If you do not have ADSL or DSL internet and still have noise you may have to call your phone service provider to get them to diagnose your line issues. They can fix some noise issues from their end.
Chris
Sep 01, 2011 | HP LaserJet M1522nf Multifunction Printer...
My modem ADSL data light keeps flashing and sometimes does not appear affecting my ability to acces the Internet. I usually have to re-boot my computer and this seems to solve the problem for a time. It is...
I usually have to re-boot my computer and this seems to solve the problem for a time. It is very inconsistant and anoying.Thank youM. Davis
ADSL DATA light flashes says there is internet activity (Internet status: Connected)...
ADSL DATA when off says there is no internet activity (Internet status: Not Connected)...
This occurs when there is a lot of noise in your telephone line...
It is adviced to do a line test in this case to find the amount of noise in your line...
If there is a lot of noise your modem will lose the internet connectivity and will try to re-establish the connection with ISP...
In this case the ADSL DATA light switches between OFF and ON...
One more thing...
ADSL SYNC light should be steady...
If it is blinking is says there is no syncronisation between your modem and ISP...
Dec 08, 2010 | Belkin Computers & Internet
I have a DSL502T ADSL Router,and have bought a new emachines computer. I can not connect to the internet. The computer has a wireless connection loaded but I want to connect by dailup Please could you help...
You are a bit confused with the various components required for Internet connections.
If you have a dial-up connection with an Internet Service Provider, all you do is connect your computer's modem port to the phone line and dial the phone number of your Internet Service provider.
If you are connected to the Internet Servise Provider by ADSL and have a combined ADSL router and modem then you connect the phone line to this router/modem. If the ADSL modem is separate component then the phone line is connected to the ADSL modem and this modem is connected to the router with a LAN cable and the computer is connected to the router with another LAN cable. If the route is wireless and the computer has a wireless card then you don't need a LAN cable between the router and the computer.
If you are connected to the Internet by ADSL, to secure your Internet connection and configure your computer so it can connect to the Internet, please follow my instruction - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 17, 2009 | Computers & Internet
My ex-next door neighbour has recently flitted 20 miles south. He can no longer connect to the Internet via his BT Voyager ADSL Router. I think he has lost an essential connection during the removal. In...
Your ex-next door neighbour needs to contact his Internet Service Provider to get a new ADSL connection linked to his new phone line. The original ADSL connection is tied to his old phone line/number and it will not work in his new location. Each ADSL connection is setup at the local telephone exchange and tied to that phone line/number..
If his Internet Service Provide does not operate nor can provide an ADSL service in his new area then he needs to find a new Internet Service Provider.
Oct 22, 2009 | Computers & Internet
Intermitent internet connection the lights on the router are all steady until i connect to internet then the adsl and the online lights flash or go out sometimes i get online but very slow then the...
This is due to noise level(poor SNR) variations in the incoming ADSL line. Check the splitter or try replacing with a new one.
Remove any parallel phone connection on the same line.
Oct 18, 2009 | Computers & Internet
Adsl modem giving very slow and intermittent internet connection
this is not a problem with ur PC or router this could be in the Filter or splitter that ur ISP gave you, what i would do is call ur ISP and have them run a line test that could be the reason
i work for att. and that does happen ALOT you can also go to
www.speakeasy.net go to the bottom you should see whats my speed or test ur speed click on that and select a server closest to you and it will run a speed test up and download speed
good luck ,
July
Apr 11, 2009 | Computers & Internet
Dont know how to configure
I have no internet connection
Mar 30, 2009 | Computers & Internet
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
The router continues to show up to 5 computers as on line, when they are not even with 2 of the 5 having the same mac address. this seems to be causing the security to fight what appears, itself. it takes...
We are always available at Avast Antivirus Tech Support Phone Number1-866-877-0191 on 24*7 hours. You can completely free to contact us on Avast Antivirus Tech Support Phone Number 1-866-877-0191. You will get the best resolution of all issues. Just call here anytime.
http://resolit.us/Avast-Antivirus-Support.html
Aug 08, 2017 | Hawking AR740 ADSL Router with Modem
Zoom ADSL X6 Modem "Link" Light Suddenly Blinks Continuously
the modem may have gone faulty so if your isp provided it ask them to replace it if the modem is in warranty period and if your isp provides internet connection through the phone line then first please try plugging the modem on main socket in with an adsl filter plugged in and if this is not the case then problem is definately the line through which the broadband signal come to your place which is suppose to be sorted out by your isp.
Mar 12, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
