Question about Vehicle Parts & Accessories
What can be the problem on an alfa romeo gtv airbag light not going off even if you resrt it and fix all the connecters under the driver and passenger seat
Pascal
  • 918 Answers
Make an computerized diagnostic
Posted on Jul 13, 2017
SOURCE: 2003 alfa romeo spider electric roof does not open
Thank you Thank you Thank you.. The tapping of the motor in the battery compartment really worked.
Thank you kindly.
Posted on Aug 09, 2008
  • 104 Answers
SOURCE: need electrical wiring diagram alfa romeo gulietta 2.0 executive
Sign up at alldata http://www.alldata.com/products/index.jsp
for their DIY service for your car. It will include wiring diagrams
good luck
Posted on Mar 17, 2009
rscheutz
  • 54 Answers
SOURCE: BMW 530i airbag light turns on when passenger sits
Most likely there is a sensor in the seat that can tell when there is a passenger. My '95 325 had this feature...I believe it was to prevent the airbag from deploying unnecessarily in an empty seat, although that's just a guess.
BMW's are renowned for having airbag light issues, it could be any number if things. Most likely though, the airbag would still function if need be.
If you are overly concerned about it, I would take it to a mechanic that can read the trouble codes to see exactly what type of airbag problem you are having.
Posted on Mar 22, 2009
  • 21 Answers
SOURCE: how to fix the tilt steering.. won't go down even when you push the auto button. My heated seats ain't workin either..(driver & passenger seat)
Most often, the stuck steering wheel is a result of a faulty 'tilt relay switch.' If you attempt to use the tilt switch and you can hear a clicking/whirring noise, then its your relay switch, if not, it may be the motor that is broken.
Posted on May 30, 2009
  • 1348 Answers
SOURCE: 2005 cadillac cts has the airbag light on , i
the computer knows that input data from a system has a problem,so disconnecting the battery will not help.
that is the procedure for working on it so that the airbags do not deploy.
a code scanner will tell you which part of the system,including a seatbelt latch,tensioner, or seat position sensor is defective.
Posted on Sep 14, 2009
Testimonial: "thank you for your help , but i was trying to avoid paying to the " scanner ""
1974 alfa romeo gtv -motor mounts
Join Alfa Club to assist in finding parts, wiring diagrams, etc! Here's my 1974 GTA!
Dec 29, 2012 | 1974 Alfa Romeo GTV
Alfa Romeo GTV run out of petrol now not start
Smack the bottom of the fuel tank in the center. If the pump starts working again, replace the pump. Old pumps can't take a dry run. they tend to lock up. smacking the tank shakes them sometimes and they will work. But this is only temporary. It will eventually quit all together.
Sep 04, 2011 | 2000 Alfa Romeo GTV
Diagnostic check warning light on. engine stalls. car alfa spider twin spark with low mileaga (20,0000 mls) Oil level ok and no engine noises.
hello i have a spider gtv on a 99, as the engine gets upto temprature the warning light flashes and once the engine is hot the oil light stays on, only on tick over. i have changed oil pressure switch. still the same though.
Dec 31, 2010 | Alfa Romeo Spider Cars & Trucks
Alfa gtv 3.0 water in oil
there is really only one common thing that causes this problem, that is a leaking engine cylinder head gasket.
Sep 10, 2009 | 2000 Alfa Romeo GTV
Alfa GTV brake piston repair
As their is a lot of preasure on them it would be best to clean and smooth the face of the piston and use a copper washer. Tried all kinds of chemical metals and sealers non I would trust on brake's.
Aug 10, 2009 | 1982 Alfa Romeo Spider
My alfa gtv ts has developed a squeek in the
The timing belt is synchronous and will not slip. if it did your car wouldn't run. it is most most likely a drive belt. replace the drive belts. if that doesn't fix it then one of the pulleys is going bad. its hard telling which one.
Jun 28, 2009 | 2000 Alfa Romeo 145
Fuel gauge not working on alfa gtv 1998
Sounds as though the tank sensor is faulty. Access through top of petrol tank, note the wiring colours and position. Lift out and check condition of float and the rheostat wiring and slider. Get a replacement from EB spares
Nov 13, 2008 | 2000 Alfa Romeo GTV
The airbag warning light is on 156 2.0 2002
hi,
go to a alfa romeo service. They will connect your alfa to fiat examiner. And will delete the airbag error from your cars ECU.
regards from Turkey
Jul 29, 2008 | 2000 Alfa Romeo 156
Vehicle Parts & Accessories Logo
120 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
