Question about Refrigerators
My fridge is freezing the veges in the crisper & the milk in the door
    Habit-Forming:
  • 154 Answers
Lower (raise) temp control knop down one number at a time waiting 2 hour in between (if pointer is on 9 turn to 8 and so on.... also put a temperature gauge inside refig. to check temp, you want it as cold as possible but not freezing.
Posted on May 16, 2017
I have a westinghouse fridge freezer and it has a humidity drawer/crisper for the fruit and veges
then turn the dial at the top of the unit to a lower number . READ your manual
Sep 25, 2015 | Westinghouse Refrigerators
Hi the vege draw on the bottom always freezers the veges the draw above is fine i have tried sliding the open/close lever also where to purchase replacement draws and milk shelf
USUALLY A PROBLEM WITH THE AIR FLOW DAMPER CONTROL AND OR THE FRIDGE THERMISTORS> IS THE FREEZER OK? IF U HAVE A BAD DOOR SEAL OR CLOGGED DRAIN PLUG U CAN GET CONDENSATION THAT MAY FREEZE AT BOTTOM AS WELL
Mar 16, 2015 | Refrigerators
Our 3 year old GE refridgerator door seems to slam shut. could you give me some ideas for me to check and our refridgerator seems to be freezing the food. It freezes the milk on top shelf and freezes our...
make sure the fridge feet are even at the front it would seem the feet are too high and the fridge is on a backward lean allowing gravity to slam the door as there a re no springs in the door it can only be this
merry christmas
Dec 21, 2010 | Refrigerators
Water not working, ice is. fridge is set at 2.stuff freezing
i have this exact same problem. Started about 3 months ago with the crisper and now the water. when I turn the fridge off after a few hours the water works again. I'm calling the repair person tomorrow
Jan 30, 2010 | GE Profile Arctica 25.4 Cubic Feet...
The bottom crisper in my refrige freezes my veggies
To repair this problem I dont think just toggling a lever is going to work. You need to locate what is suppose to sense the temp in the fridge section and how it stops the air flow to the fridge section. Basically most refrigerators cool in the freezer using the freon coils and transfer the cold to the fridge section using the fan in the freezer. Then your thermostat (temp sensor) stops the air flow by either turning off the fan or closing a small door going to the fridge section. This door is called the baffle and if you put your hand up to it and can still feel air coming thru when the temperature is 39 degrees or lower its not doing its job. With a model number I could help better but my guess is if its not freezing everything only the veggies your thermostat is off or the baffle is unable to close all the way and may have ice or debris in it. Either way I hope this helps.
Jan 24, 2010 | Refrigerators
Food in fridge is freezing.
I need your model number, you may have a problem with your thermistat. Sears uses a different model number system than everyone. The model number will look like this 231.0564879 for example. Or yours may have electronic vents. Let me know, Thanks, Sea Breeze
You may need to contact me because Fixya has a problem letting me know if you respond.
appliancepartsse@yahoo.com
Jul 20, 2009 | Kenmore 53082 / 53084 Side by Side...
Crisper door/water line freeze problem
mar...you're box is set too cold. Use -17 C/38 F on the freezer side which is about 38F/4C on the fridge side. Use an outdoor thermometer and let it sit closed for at least a few hours. Adjust accordingly and this will work out. One adjustment is often the cold vents from the freezer into the fridge. If set too wide, too much cold air gets into the crisper and water lines.
Feb 01, 2008 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
