What does the FL display means in my carrier air condition unit?
  • 9,257 Answers
Probably time to clean the filter
Posted on May 16, 2017
Receiving error code FL on washer display.
The FL error code means:
Flood Condition:FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
Dec 07, 2012 | Crosley CW6000 Front Load Washer
Problem with a Condura A/C. It displays an "FL" error on the LED display. What does this mean and how do I get rid of it?
FL means, filter check warning. To get rid of it, Press the 'mode" and " " (down) buttons simultaneously for 3-5 sec.
May 22, 2011 | Carrier 38CKC024 Air Conditioner
WHAT DOES FL MEAN AND HOW DO I FIX MY WASHER WHEN
Flood Condition:
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Flashing FL
Hi
If you have error code FL it means flood condition i.e. FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
If its LF which means long fill i.e. when the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
What does F1 means
Could it be FL?:
FL Flood condition "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed.
With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Aug 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
MY WASHER IS BEEP AND DISPLAY FL
FL means flood condition
Solution: "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Jul 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
It says FL
Jul 15, 2009 | Kenmore Washing Machines
What does FL mean when it comes on washer ?
***If there was not an Overfill condition and, the SUDs were not present when this alarm was initiated, thsi will confirm a faulty Overfill switch and, it should be replaced.
Jul 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My ac is carrier company window a/c its indicating {fl}
From the manual.
Message on the display(electronic models) E4 1. Failure in the inside temperature sensor E5 2. Failure in the outside temperature sensor FL 3. Dirty filter
To fix vaccume  (or wash your filter) then  hold down "Select"(or "Mode") and "-" (or "^") for 3 secconds.
Jan 30, 2009 | Carrier 52PQ307 Wall/Window Air...
What FL stands for?
FL means change filter media
Sep 13, 2007 | Carrier 38CKC042 Air Conditioner
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
