Question about Brother Sewing Machines
The buttonhole leaver on my brother ps-33 doesn't stay back when pushed how can I fix this?
  • 4 Answers
SOURCE: buttonhole lever
If you remove the cover on the upper left portion of the machine, while looking from the left to the right.....Above the BH lever area, you will see a round cam with a post through the middle. Rotate the round can ( with fingers on it), and try again. This will change the angle position on the lever, and hopefully correct your problem. You may have to go a couple of clicks in either direction.
Posted on Nov 26, 2007
  • 86 Answers
SOURCE: I need to know how to change the bulb on a brother
Hi, thank you for using FixYa! I don't see a model PS-33, however; you posted in the CS-8150 machine section, the link to the manual for a CS-8150 machine is attached. It has a section for winding and installing the bobbin and another section for upper threading. If your machine is not the CS-8150, please comment with the correct model number (PS machines start at number 1450 and increment upwards). If this is the correct manual, would you please take minute to rate this solution? Thank you! Gregg
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_8150_EN_183.PDF
Posted on Mar 29, 2009
  • 1788 Answers
SOURCE: Is there a manual for
If, you go to www.brother-usa.com you can download manuals for free. But, I did not see one for your model. Are you sure that is the right number? It may have more numbers on the machine itself, next to the serial number. If, that fails, call them at customer service 1-877-276-8437 and they can help you.
Posted on Sep 18, 2010
SOURCE: brother ps 33
1:cose com a linha da canela muito largo.
2:Faz bolas de linha
Posted on Aug 22, 2011
Joe Onley
  • 363 Answers
SOURCE: Hi, I lost my manual for my Brother PS-33 (16
I went to the Brother site, (link below) follow the directions and insert relative information to receive information from the manufacturer.
http://www.brother-usa.com/manuals/default.aspx?PGID=3
Hope it helps, good luck
Joe
Posted on Aug 29, 2011
Buttonhole not sewing
Sounds like something's keeping the foot from moving freely. See: http://picturetrail.com/sfx/album/view/24536843 -- the aborted buttonhole to the left of the second photo was caused by the foot hitting the slightly raised lid of the accessory box. Ooops. Fix was to take off the accessory box.
Jan 20, 2014 | Brother CS-6000
Automatic button hole not working in ambition 1.5
it sounds like the machine needs some adjustment in the buttonhole
gears or the cam could be damaged.
Jan 04, 2013 | Sewing Machines
Brother sewing machine cs2000i botton hole problem as follows the foot stays in place and does not feed. I have changed the thread, looked at the video, clean any clogs. What is it?
it does not specify if this machine is electronic or mechanical, but electronic sewing machine,,like mine have what is called a buttonhole lever & unless that buttonhole lever is pulled gently down the buttonhole maker will not work.
that may be the problem with the machine
or it maybe the feeddogs may not be working,,check the feeddog knob or lever to see what position it's in,,up position is for sewing & down position is for darning
Feb 01, 2012 | Brother Sewing Machines
My machine has a one Step Buttonhole Feature - having problems
Try an Even Feed Walking Foot for more control on thick and quilted type layers
Dec 10, 2011 | Brother CS6000i Computerized Sewing...
Joe
Aug 29, 2011 | Brother PS-1250 Pacesetter
Machine shows 2 E whaat can I do to fix it
Have you got a manual?
If not one is available free to download from the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
Look on page 64 of the PDF file for the error codes.
E2 means:
Problem: A stitch other than the buttonhole or bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Solution: Raise the buttonhole lever
before continuing the operation.
Hope this helps!
Sep 24, 2010 | Brother CS-6000
Trying to do a buttonhole and it keeps telling me that the buttonhole lever is not down when it is.
Did you push it to the back a little? Sometimes that is all that it takes for it to engage, good luck
Sep 08, 2010 | Brother PC8500D
I have a Janome New Home machine and I was using my buttonhole lever and it seem to get stuck and now I think I pushed it too much and it is off track or I broke it. Can I fix this myself? It won't even go...
Sorry, I didn't see your second posting with the model number.
I'm not sure which screw you removed, but the buttonhole lever mechanism requires the service manual to reset the position.
Jul 19, 2009 | Sewing Machines
I need to know how to change the bulb on a brother ps 33 sewing machine!
Mar 29, 2009 | Brother CS-8150 Computerized Sewing...
Buttonholes
First be sure to follow the steps described in the manual for attaching the buttonholer.
Second, check that the buttonhole lever is pushed because it returns to it's unpushed state after a buttonhole is completed and therefore it will stitch in the same spot.
Also, try adjusting the stitch length. I've found that I can't make buttonholes while on the satin stich setting ( that little rectangle) but if I move it just a bit towards 1 it will manage to make the right stitches.
Feb 11, 2009 | Brother XL-5700 Mechanical Sewing Machine
Sewing Machines Logo
23 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
