Lights all flash and tells me to remove cartridge and check. I've replaced cartridges, cleaned cartridges, done all that HP tells me. It won't let to perform any functions.
  • 1 more comment
  • fhdmed Jul 25, 2009
    Carlsbiz
    First off, I don't know how FixYa got Web Cam as my problem. My problem is with an
    HP PSC 2175. I've tried your suggestion and several other resetting suggestions. They don't work. I've uninstalled HP software and reinstalled. No good either. I've cheched the various "solutions"
    send into FixYa too. It started with the replacement of a cartridge and that would not align; tried another one , same thing. I was able to bypass alignment, but then got "paper jam". Then even that stopped and I got the "remove cartridge and check." Any other suggestion?
    fhdmed
  • fhdmed Aug 17, 2009
    I have replied and tried all posted suggestions as of Aug 4th. This posting did not have any new "solutions although the Email said there would be one. You have already charged my the 12.99 onto my credit card although I have not accepted any "solution. Where do I go from here?
    fhdmed
  • fhdmed Aug 18, 2009
    I don't think it pays for me to go with expensive repairs as new printers are probably cheaper. You have my 12.99 for your time. I will not proceed with FixYa.
    Thanks.
    fhdmed
    President:
  • 3,278 Answers
Your printer needs to be restarted. From the HP Website:
  1. Turn the printer off and then turn it on again.
  2. If the problem persists, turn off the printer.
  3. Disconnect the power cable from the power source.
  4. Reconnect the power cable and turn the printer on.
If not resolved, check for a paper jam.
Hope this helps.
Posted on Aug 04, 2009
  • NinaE Aug 04, 2009
    OK. In relation to what Ted was saying regarding the carriage, clean the contacts in the carriage with water, a damp paper towel or coffee
    filter. Test the printer before trying the next step.
    Try cleaning the contacts on the
    cartridge again, with water. Use the scrubby side of a kitchen sponge, wipe with
    an up/down motion twice. Just be careful. More scrubbing may remove the plating from
    the contacts. (up/down is with reference to the top of the cartridge when it's
    installed).
    If still a problem, the carriage board
    and/or cables may need to be replaced.
  • NinaE Aug 17, 2009
    So, you replaced the cables and carriage board with the same results ???
  • 339 Answers
Here are a couple of things that may help solve your problem.
1. Turn off the printer and move the cartridge carrier to the side so you can see the encoder strip. It's clear plastic with black markings on it. Clean this with alcohol and a cue-tip or whatever you have available. Be gentle.
2. Remove the cartridges and clean the contacts.
After doing the above, try printing again. If this doesn't work, try to update the firmware, this can cause problems at times as well if HP has recently changed anything in the logic chip on the cartridges.
Posted on Jul 25, 2009
    President:
  • 1,124 Answers
Try unplugging it for several minuets to clear it.. That worked for me a few times when my printer did this..
If not - it might be a falty componet - very technical..
Hope this helps - rate well ;o)
HP Photosmart C4140 error message won't go away Remove and check color cartridge. I have done this and unplugged, checked both color and black cartridges...won't go away.
hey, sometimes there are faulty cartridges. i use to got some brand new and original from the shop and not working.. so try it with some old cartridge if you have.. you can also try to remove the cartridge and clean/wipe the contacts on the cartridge side and on the printer side (turn of the printer for safety)
Sep 18, 2011 | HP Officejet 5510 All-In-One Thermal...
Hp officejet 6110 all-in-one printer -- Getting error message "Press Enter to align cartridge." We've had this error before and did as instructed and it's corrected itself. However,...
remove the cartidges.
Take a damp paper towel and clean the contacts of the cartridges and also the contact inside the holder of the cartridges.
put back the cartridges.
Print a self test
Also clear the the printer memory
Jul 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
My HP 2210 PSC all in one printer has all 4 lights flashing and tells me to remove and check cartridges. I have replaced both color and black and whited with new ones but still tells me to check and remove...
Unplug the printer for 15 minutes and plug it back in. You need to clear the memory out of the printer, and by unpluging it for that long usually does the trick.
Oct 10, 2009 | HP Office Equipment & Supplies
Flashing lights remove and check cartridges
Try this... At the top are instructions for replacing the cartridges. Farther down are instructions for what to do if you get messages related to your cartridges. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu05206&cc=us&lc=en&dlc=en&product=90809
Jun 09, 2009 | HP PSC 2175 All-In-One InkJet Printer
HP 2210, screen says to press enter to aling cartridges
Once you replace a cartridge on a 2210 ya page prints and you must put that page on the scanner window and then press enter. Your computer will go through a calibration to align the print head. once this is done you can throw away the paper and printing will be normal
May 27, 2009 | HP PSC 2210 All-In-One InkJet Printer
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
It keeps telling me to remove and check cartridge
I also have this same problem. I currently have refilled cartridges in there purchased from cartridge world. I never had any problems with my HP until i tried refilled cartridges for the first time about 6 months ago. When i first purchased a refilled cart. it took 3 trips back to the store until i got one that would work in my HP. so im wondering if this is why i am now getting this "remove and check cartridge" error message.? I am reluctant to go out and buy a new HP ink cartridge just to find out ill have the same problem....
Jun 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
