Question about Answer Lands Phones
Increase number of rings before auto answer - Answer Lands Phones
    Top Expert:
  • Answer Master
  • 51,505 Answers
Some have a switch on the unit others have to go into setup menu and change it there
Posted on Oct 14, 2017
Noggin
  • 944 Answers
SOURCE: setting the number of rings before answering machine kicks in
Here is the link to the user manual; http://service.us.panasonic.com/OPERMANPDF/KXTC1501B.PDF Check page 19 - you can set the answer rings from 2 to 7 Hope this helps :)
Posted on Jun 19, 2007
  • 22 Answers
SOURCE: increase rings
This is a programable item in your phone.Check your user manual.If you do not have the manual find your phone on line and look up the user manual.
tk46
Posted on Jul 20, 2008
SOURCE: Ricoh Aficio 350 change number of rings before fax answer
Can't be done..this fax can only operate on a dedicated line, and it picks up right away. Sorry.
Posted on Mar 25, 2009
Vit Avaya BP
  • 211 Answers
SOURCE: Avaya 18D Change Number of Rings
Programming is done on extension 10 or 11
Press feature 00
Left intercom, Left intercom
#506
mode 1
line 01
number of rings 4
do the same for all lines
Cheers
Posted on Apr 14, 2009
  • 8068 Answers
SOURCE: would like to increase number of rings before
Setting the Number of Rings (Excerpt from the Uniden Dect 1580 Phone manual
The ring time setting allows you to set the number of rings the caller hears before your answering system plays the outgoing message. You can set the ring time to answer after two, four, or six rings. If you enable the Toll Saver (TS) setting, the answering system picks up after two rings if you have new messages, and after four rings if there are
none. This way, if you make a long distance call to check your messages, you can hang up after the third ring to avoid long distance billing charges.
  1. Press Menu/Select.
  2. Select the Ans. Setup menu, and then the Ring Time submenu.
  3. Move the cursor to select a ring time (Toll Saver, 2 Times, 4 Times, or 6 Times).
  4. Press Menu/Select. You will hear a confirmation tone.
Posted on Feb 03, 2010
Increase number of rings before voicemail, vtechcs6419
The CS6419 isn't an answering machine. The phone will ring until you answer, an answering machine or voicemail system picks up, or the caller hangs up.
To change the ring count on an answering machine or voicemail system, refer to the documentation for that system. If you require further assistance, please add a comment to this question and identify the answering machine or voicemail system.
Jan 28, 2014 | Vtech DECT 6.0 Digital Cordless Phone
On the uniden TRU9466 is there any way to increase the number of rings before it goes into voicemail?
The TRU9466 isn't an answering machine. The number of rings is controlled by whatever answering machine or voicemail system you have on your phone line. Please refer to the documentation for the answering machine or voicemail system to change the ring count.
If you need further assistance, please reply to this post and specify the answering machine or voicemail system.
Jan 22, 2014 | UNIDEN AMERICA CORP Uniden TRU 9466 -...
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
HP L7650 will not auto answer incoming faxes
To set the answer mode to manual or automatic via the control panel
? Press Auto Answer to turn the light on or off, as appropriate for your setup.
When the Auto Answer light is on, the device answers calls automatically. When
the light is off, the it does not answer calls.
To set the answer mode to manual or automatic via the embedded Web server
1. Open the embedded Web server, click the Settings tab, click Fax in the left pane,
and then click the Basic sub-tab.
2. Select On or Off in the Auto Answer drop-down menu in the Other Basic Fax
Settings section.
Set the number of rings before answering
If you turn on the Auto Answer setting, you can specify how many rings occur before
incoming calls are automatically answered.
The Rings to Answer setting is important if you have an answering machine on the
same phone line as the device, because you want the answering machine to answer
the phone before the device does. The number of rings to answer for the device
should be greater than the number of rings to answer for the answering machine.
For example, set your answering machine to a low number of rings and the device to
answer in the maximum number of rings. (The maximum number of rings varies by
country/region.) In this setup, the answering machine answers the call and the device
monitors the line. If the device detects fax tones, it receives the fax. If the call is a
voice call, the answering machine records the incoming message.
To set the number of rings before answering via the control panel
1. Press Setup.
2. Press Basic Fax Setup, and then press Rings to Answer.
3. Enter the appropriate number of rings by using the keypad, or press the left or right
arrow button to change the number of rings.
4. Press OK to accept the setting.
To set the number of rings before answering via the embedded Web server
2. Select a number in the Rings-to-answer drop-down menu in the Other Basic Fax
Settings
section.
Dec 02, 2010 | HP Officejet Pro L7650 Printer
Number of rings to answer fax?
have an HPOfficejet 6500A Plus and the ax number of rings is preset at 2 rings before answer.
How can I Increase the number of rings?
Nov 05, 2010 | HP Officejet J5780 All-In-One InkJet...
Answer phone responds too soon
The usual numbers of rings before the machine answers is 2 or 4. If that is not enough, you are out of luck. If it's 2 now and you want 4, there should be a menu button you can press, and when you hear "number of rings" use the up/down arrows to increase the number. Then press the "set" button. Hope that helps.
Mar 05, 2010 | Uniden Cordless Phone
Increase number of phone rings
If you have subscribed to Bell Answer, just lift the receiver and dial *94. After the beeps, enter the number of rings you want before it answers. You will hear a double beep, then hang up. Your rings will have been changed to the number you selected. Repeat as required.
Feb 23, 2010 | Aastra Telecom Powertouch/Vista 390 Corded...
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
the default setting is 5 rings. if you need to change that:
set the ring to answer to higher number, however, that will put the machine in manual answering of fax.
the better setting is to rest the phone or the answer machine to a lower number of rings.
Jan 13, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Settings for fax machine
Depending on the model and make of your machine, there should be an option under the fax settings of the setup menu that will allow you to either increase the number of rings before auto answer (I suggest that you increase it to at least 5 rings to give you time to answer) or that whilst you are available change the answer setting to phone. This will mean that you have to answer all calls but if there is an incoming fax (you will hear the high pitched beeeping sound) before you place the phone back on the hook press the start button.
This should solve your dilema.
Oct 17, 2008 | Office Equipment & Supplies
Lands Phones Logo
37 people viewed this question
Top Answer Lands Phones Experts
John Donghia Jr.
John Donghia Jr.
Level 1 Expert
Are you an Answer Lands Phone Expert? Answer questions, earn points and help others
