Question about JVC Audio Players & Recorders
My jvc sound bar th-s301 can't connect to the subwoofer but before was working fine.
SOURCE: JVC TH M505 Subwoofer not working
i need to find the wire that connects from the subwoofer it has like little spikes inside the medal part and the spikes broke off
Posted on Apr 10, 2008
  • 16 Answers
SOURCE: JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Posted on Apr 16, 2008
  • 24 Answers
SOURCE: Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Posted on Feb 21, 2009
lynchms
  • 93 Answers
SOURCE: JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
SOURCE: no sound in sound bar and subwoofer
for Jameslicon re wireless sub going on and off repeatedly. Both the soundbar and the sub have 4 wireless channels - try a different pairing of those channels. There is a sliding switch on the back of both units. I set each of mine to channel 4 and the problem went away. There is also a signal level switch with 3 levels on the back of the soundbar. If the wireless channel idea does not work, try a different setting on the level switch. Good luck.
Posted on Nov 12, 2010
Subwoofer not working.
Most likely, the "remote" wire to the subwoofer amplifier has come off or is not making good connection.
May 15, 2015 | JVC TH-BA1 Soundbar System with Wireless...
Subwoofer powers on for about 4 seconds and then shutsdown
I don't know if you were able to get the problem fixed, but I had the same sort of problem where it worked and then all of a sudden it stopped working right in the middle of a movie.
I took it to a repair shop and he found that it was the power supply... a $4.00 part.
Jun 14, 2009 | JVC TH-C30 System
Jvc th-m303 sub woofer not working all other speakers are fine
check your internal wires inside subwoofer.b4 that try to connect to other instrument to make sure it not working.
May 12, 2009 | JVC TH-M303 System
Jan 12, 2008 | JVC TH-M505 System
Subwoofer shuts down
Check the connection in the back of the sub,where your wire plugs in from the DVD unit, the connector is loose in the unit itself. Had mine replaced and is doing the same thing again
Nov 24, 2007 | JVC TH-M505 System
Subwoofer Shutdown
Whay don't you take a look at your data cable and jack contacts to see if any of them are bent or misplaced. Terry
Oct 02, 2007 | JVC TH-C50 System
Subwoofer won't turn on
try and see if it as internal fuse ? if not the bad news is that possibly the amp as gone
Jan 01, 2007 | JVC TH-M303 System
Subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Sep 10, 2006 | JVC TH-M505 System
Subwoofer JVC TH-M606
What system are you using it with, how do you have it connected, when you say the system does not work as a result, does it mean that the system does not power up, or no sound?
May 19, 2006 | JVC TH-M606 System
85 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
